[mapguide-users] How do i load raster in MGOS 2?
jamesdudden jamesdudden at blueyonder.co.uk
Tue Jul 29 06:16:38 EDT 2008
I have fiddled around with a few things but have had no luck - i still can't
see the raster files.  I was wondering if somebody has some examples (i.e.
raster files and vector files plus coordinates) that i could use to test
with my setup.
One more thing i was wondering - when i click on the raster data file and
click preview there is a "view data" hyperlink but the "geometry" hyperlink
is blanked out - is this normal?
Many thanks for your help
Regards
James Dudden
Kenneth Skovhede, GEOGRAF A/S wrote:
> You need to either change the coordinate system of the map to be XY-M
> (easy, but not may not be desireable for other data).
> Or add a coordinate system override to the raster featuresource, mapping
> XY-M to EPSG:4019.
> The last option requires that your raster data is coordinate value
> compatible with EPSG:4019.
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18709174.html
