[mapguide-users] Import Views from Oracle Spatial
Alexander Fischer deejot at gmx.de
Tue Jul 29 08:19:23 EDT 2008
I tried all. First I used SqlSheet for giving the views a primary key and/or
a spatial index but both is not allowed to a View.
Also I downloaded fdo2fdo but I didn't get a connection to my database with
this although it works with MapGuide Maestro and I used the same settings.
But fdo2fdo gives the error "ORA-12154: TNS: could not resolve the connect
identifier specified"
2008/7/29 Zac Spitzer <zac.spitzer at gmail.com>
> try creating a spatial  index on the view
> On Tue, Jul 29, 2008 at 12:59 AM, A. Fischer <deejot at gmx.de> wrote:
> > Hello together,
> > when I create a new Layer in MapGuide I can only select the tables from
> my
> > database but not the views.
> > Now I read here, that I have to insert the views into the
> > user_sdo_geom_metadata - table:
> > INSERT INTO user_SDO_GEOM_METADATA  VALUES ('VIEW_NAME',
> > 'GEOM',SDO_DIM_ARRAY(
> >    SDO_DIM_ELEMENT('X', -1000000, 1000000, 0.005),
> >    SDO_DIM_ELEMENT('Y', -1000000, 1000000, 0.005)
> > ,NULL)
> > But I still can not select my VIEW from the list. Is there something else
> to
> > do?
> > I would be pleased to receive an answer.
> > Kind regards, Alexander Fischer
> > View this message in context:
> http://www.nabble.com/Import-Views-from-Oracle-Spatial-tp18689745p18689745.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080729/e69ab140/attachment.html
