[mapguide-users] How do i load raster in MGOS 2?
jamesdudden jamesdudden at blueyonder.co.uk
Tue Jul 29 09:11:15 EDT 2008
I did create it manually so i followed your advise tried using the script
from the GDAL notes webpage and it keeps giving me an HTTP 500 Internal
Server Error.
DO you know if this works with MGOS2?
Regards
wkhattak wrote:
> hi,
> Did you create your data resource using the script (GDAL notes webpage) or
> did you create it manually? If you created it manually then yeah the
> Download option would be greyed out, in that case create it using the
> script (php page that you need to download and put it in your www folder).
> The extents are the lower left & upper right coords as they appear in the
> 'Initial View' within the map tab.
> regards,
> W Khattak
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18711780.html
