[mapguide-users] describe schema problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jul 31 05:06:56 EDT 2008
If you enter a blank value, you will get the results for all schemas.
If you enter "SHP_Schema", you will get the SHP_Schema's.
You can get all the valid schemas by calling "GETCHEMAS":
http://localhost:8008/mapguide/mapagent/getschemasform.html
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> Can somebody show me a value which works for schema
> on the describe schema web form?
> http://localhost:8008/mapguide/mapagent/describeschemaform.html
> using this example
> Library://Samples/Sheboygan/Data/Rail.FeatureSource
> I always get  "An exception occurred in FDO component. Invalid Schema name"
> mg 2.0.1 on windows
> z
