[mapguide-users] Fusion map insists onrefreshing map on selection, and clear selection...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jul 31 09:44:19 EDT 2008
Thanks Jason - I guess that's not so hard! I'll give it a shot...thanks
again!
Andrew
Jason Birch wrote:
> Hi Andrew,
> While I believe that it would be possible to set up nightly builds for
> Fusion, it would be more work for you to deal with these than with
> SVN. It might look daunting, but SVN is really easy to work with:
> - install TortoiseSVN (http://tortoisesvn.net/downloads)
> - rename your existing fusion directory to fusion_old
> - create a new empty fusion directory
> - right-click on the new fusion directory and
>   - choose SVN Checkout
>   - enter http://svn.osgeo.org/fusion/trunk/ into the URL field
>   - click on OK (or something like that)
> - copy all of the contents of
>   - fusion_old/templates/mapguide    to
>   - fusion/templates/mapguide
> That should just work, and now any time you want to update to the
> latest build, you can right-click on the fusion directory and say "SVN
> Update".  You don't ever need to re-copy the templates, and for the
> cost of these few extra steps staying on top of trunk is now a
> single-click effort.  If you need to go back to the original fusion
> for some reason, you can just rename the directories back with no ill
> effects.
> If you do go down this path, I think someone mentioned on the Fusion
> list that you might need to add application/json to the MIME types if
> you're running Windows Server 2003 with IIS.
> Jason
> *From:* Andrew DeMerchant
> *Subject:* Re: [mapguide-users] Fusion map insists onrefreshing map on
> That and the SVN are simply too much extra work for those of us just
> interested in testing stuff. The SVN for Fusion has so many files and
> folders, it's not possible for someone to just 'know' where to put
> stuff on their system to make it work. A zip file would be nice, like
> on the GetIt page.....Why can't the build scripts be automated to
> build stuff every night/week and then put it somewhere? That seems
> like a pretty simple thing to do, provided we have access to a server
> somewhere.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
