[mapguide-users] Fusion map insists onrefreshing map on selection, and clear selection...
Paul Spencer pagameba at gmail.com
Thu Jul 31 11:29:37 EDT 2008
One thing that has changed in the templates is that
OpenLayers.String.translate has changed to OpenLayers.i18n - the
translate function is used in some of the templates, that is likely a
good place to start.
Cheers
Paul
On 31-Jul-08, at 10:15 AM, Andrew DeMerchant wrote:
> Ya, I see that it's fixed! It did break a few templates though, it
> seems - but I may just need to rebuild my Fusion Map in Maestro/
> Studio.....It definitely does seems better. If I can get my
> templates working again now, I may be able to use fusion for my
> clients! Thanks!
> Berdel, Brian wrote:
>> And the latest trunk does fix that issue!  Just be careful  if you
>> use setSelection with the latest version…you have to update some of
>> the code for it to work.   It is documented here
>> http://trac.osgeo.org/mapguide/ticket/630
>> Brian
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org
>> ] On Behalf Of Andrew DeMerchant
>> Sent: Thursday, July 31, 2008 9:44 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Fusion map insists onrefreshing map
>> on selection,and clear selection...
>> Thanks Jason - I guess that's not so hard! I'll give it a
>> shot...thanks again!
>> Andrew
>> Jason Birch wrote:
>> Hi Andrew,
>> While I believe that it would be possible to set up nightly builds
>> for Fusion, it would be more work for you to deal with these than
>> with SVN. It might look daunting, but SVN is really easy to work
>> with:
>> - install TortoiseSVN (http://tortoisesvn.net/downloads)
>> - rename your existing fusion directory to fusion_old
>> - create a new empty fusion directory
>> - right-click on the new fusion directory and
>>   - choose SVN Checkout
>>   - enter http://svn.osgeo.org/fusion/trunk/ into the URL field
>>   - click on OK (or something like that)
>> - copy all of the contents of
>>   - fusion_old/templates/mapguide    to
>>   - fusion/templates/mapguide
>> That should just work, and now any time you want to update to the
>> latest build, you can right-click on the fusion directory and say
>> "SVN Update".  You don't ever need to re-copy the templates, and
>> for the cost of these few extra steps staying on top of trunk is
>> now a single-click effort.  If you need to go back to the original
>> fusion for some reason, you can just rename the directories back
>> with no ill effects.
>> If you do go down this path, I think someone mentioned on the
>> Fusion list that you might need to add application/json to the MIME
>> types if you're running Windows Server 2003 with IIS.
>> Jason
>> From: Andrew DeMerchant
>> That and the SVN are simply too much extra work for those of us
>> just interested in testing stuff. The SVN for Fusion has so many
>> files and folders, it's not possible for someone to just 'know'
>> where to put stuff on their system to make it work. A zip file
>> would be nice, like on the GetIt page.....Why can't the build
>> scripts be automated to build stuff every night/week and then put
>> it somewhere? That seems like a pretty simple thing to do, provided
>> we have access to a server somewhere.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> <mime-attachment.gif>
>> Andrew DeMerchant
>> Computer Technologist
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> <logo.gif>
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
