[mapguide-users] 2.0.1 install server 2003
Berdel, Brian brian.berdel at mcmtrans.com
Thu Jul 31 11:36:23 EDT 2008
n
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
Sent: Thursday, July 31, 2008 11:20 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 2.0.1 install server 2003
you shouldn't need to move your php.ini file from the php folder under
WebServerExtensions
remove all other copies of php.ini you may have on the system.
you can create a file in the mapviewer folder and give it a .php
extension
and inside type:
<? phpinfo(); ?>
save and then navigate to this page in a browser and it will give you
the
php configuration settings.
"Loaded Configuration File" should be set to the php folder under
WebServerExtensions
Berdel, Brian wrote:
> I am actually using the .net bundled config.  I have no other PHP
> versions setup.
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Thursday, July 31, 2008 8:47 AM
> Subject: Re: [mapguide-users] 2.0.1 install server 2003
> Did you use the bundled PHP package or one that you downloaded?
> If you haveother PHP versions set up, you may need to remove them to
> keep
> MapGuide from getting confused.
>> Hello all,
>> I have 2.0.1 installed on my development machine, but have been
unable
>> to get the web server extensions to function correctly on server 2003
> R2
>> Getting Fatal error: Call to undefined function MgInitializeWebTier()
> in
>> C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapadmin\login.php
>> on line 70
>> When going to the admin page (with errors turned on)
>> I have moved my php.ini file to the windows directory and checked the
>> registry setting
>> Fatal error: Call to undefined function MgInitializeWebTier() in
>> C:\Program
>> on line 70
>> Brian Berdel
>> Applications Development Manager
>> 425 Commerce Drive, Suite 200
>> Fort Washington, Pennsylvania 19034
>> p: 215.283.9444
>> f:  215.283.9858
>>   <http://www.mcmtrans.com>
>>    New England  |  Mid-Atlantic  |  Florida
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/2.0.1-install-server-2003-tp18742286p18753793.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://www.nabble.com/2.0.1-install-server-2003-tp18742286p18756959.html
