[mapguide-users] MG 1.2 vs 2.0.1
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 31 21:05:44 EDT 2008
yep...it does fail silently, which is really annoying.. it should just
raise an exception
On Fri, Aug 1, 2008 at 4:16 AM, George McLean <gmclean at gorge.net> wrote:
> No I am not. Does this ignore the error message and process the update
> somehow?
> Zac Spitzer wrote:
>> Are you checking the result as bellow
>> result=featureService.UpdateFeatures(resourceID, fCommand, false);
>> if (result.GetItem(0).GetPropertyType() eq 9)
>>    result.GetItem(0).GetValue() // Silent FDO error messages!!!!
>> z
>> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>> can you post some code to demonstrate the problem?
>>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net> wrote:
>>>> Hello,
>>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues with
>>>> adding
>>>> data to feature sources discussed in this thread:
>>>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-to16392736.html#a18556960
>>>> My immediate issue is that I have a client that would really like to us
>>>> FF
>>>> 3.0 with my application. I see that either I need to find a way to apply
>>>> the
>>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues with
>>>> updating feature data.
>>>> I could look at the code for MG 1.2 and apply the changes made to 2.0
>>>> with
>>>> some guidance on where to start but I think I would rather find a fix
>>>> for MG
>>>> 2.0.
>>>> Any suggestions would be appreciated.
>>>> Thanks
>>>> George McLean
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
Zac Spitzer -
+61 405 847 168
