[mapguide-users] Cannot Establish Connection
Rock Beans rockbeans at gmail.com
Thu Jun 12 13:41:48 EDT 2008
Might as well use PHP for the viewer since it is required anyway for the
MapAdmin.
On Thu, Jun 12, 2008 at 11:39 AM, Mark Pendergraft <markp at meadgilman.com>
wrote:
>  Oops.  Meant IIS 5.0
> I am using .NET
> For providers I am using only SDF
> I will monitor the Access logs and if anything suspicious pops out at me, I
> will post that as well.
> Again, thanks for any help provided.
> -Mark P.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Dave Wilson
> *Sent:* Thursday, June 12, 2008 9:26 AM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] Cannot Establish Connection
> How did you manage to get IIS 8.0 running on Windows 2000? Are you using
> .NET? Microsoft changed the behavior of Applications pools at some point so
> that they will dump with an error where they didn't before. This could be
> related to your behavior. It might not be.
> Use the Access logs to determine the last set of operations you were doing
> and try to figure out if certain data is causing problems.
> Which providers are you using?
> Dave
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Mark Pendergraft
> *Sent:* Thursday, June 12, 2008 10:21 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] Cannot Establish Connection
> Ever since moving to MGOS 2.0 my map keeps crashing and giving users a
> "Cannot Establish Connection" error.  It appears the service is actually
> stopping on the machine hosting the map, and I have to go in and restart
> it.  It happens about every other day, and sometimes several times a day.
> The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
> Any ideas on why this is happening?  It's really starting to get annoying,
> and if I can't find a fix then I will have to downgrade to 1.2.
> Thanks.
> -Mark P.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080612/1ab63a29/attachment.html
