Hi All
I try to amend the mapguide.conf from Apache conf folder, the amendment
part is as following:
# MapViewer to MapViewerPhp aliases
ScriptAlias /mapguide2009/mapagent/mapagent
"/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/mapagent/mapagent"
AliasMatch ^/mapviewerphp/([^?])(.*)$
"/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/mapviewerphp/$1$2"
AliasMatch ^/mapviewerphp/(.*)$
"/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/mapviewerphp/ajaxviewer.php$1"
Alias /mg
"/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/App/"
<Directory
"/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/App/">
AllowOverride All
Options All
Order allow,deny
Allow from all
AddHandler php5-script .php
AddHandler mgmapagent_handler fcgi
RewriteEngine on
RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
</Directory>
Eventually the map frame shows "You don't have permission to access
/mapviewerphp/ajaxviewer.php on this server.".
The part of index.php is as following:
<frameset rows="100,*" frameborder="NO" border="0" framespacing="0">
<frame src="title.html?AppName=AJAX" name="TitleFrame" scrolling="NO"
noresize>
<frame src="../mapviewerphp/ajaxviewer.php?SESSION=<?php echo
$sessionId; ?>&WEBLAYOUT=<?php echo $webLayout; ?>" name="ViewerFrame">
</frameset>
BUT if the mapguide.conf is amended as following:
Alias /mg "/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/"
<Directory "/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/">
It is work!! but I don't want the user can access another folder in www
root directory. How I can do it?
Regards,
Eric
