[mapguide-users] Theme functionality of PHPSAMPLES
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jun 17 04:40:01 EDT 2008
The path is from the machine that built MapGuide.
You cannot find it on your machine, but you can look in the source code
for MapGuide if you like.
What do you change the library to?
Regards, Kenneth Skovhede, GEOGRAF A/S
erictsn at cadbeyond.com skrev:
> Hi All
> This is the example application, is deployed "$webLayout=
> "Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout";. It works
> fine with the theme functionality. I tried to change the library. It work
> fail! It prompts the following error:
> Error
> The specified class was not found.
> The specified class was not found. Exception occurred in method
> MgServerDescribeSchema.GetClassDefinition at line 1403 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
> I try to check all file, can't to find this path
> "d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev...".
> Anyone knows how to fix?
> Regards,
> Eric
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
