[mapguide-users] Fusion Error When Selecting From Search Results
Zac Spitzer zac.spitzer at gmail.com
Sun Jun 29 22:49:44 EDT 2008
are you using the latest fusion? ie 1.0.6 not the bundled 2.0.1 version
http://trac.osgeo.org/fusion/wiki/GetIt
There is a good case for a MG 2.0.2 point release as there are quite a
few fixes available/pending,
for stylisation, browser support ( opera & ff3 ), the lastest fusion
and some other fixes
2.0.1 was at subversion rev 3184, subversion is currently at 3225
http://trac.osgeo.org/mapguide/log/trunk?action=stop_on_copy&rev=3225&stop_rev=3184&mode=stop_on_copy&verbose=on
It is a bit confusing because Maestro is in there as well
anyway there's nothing stopping you building your own version
On Mon, Jun 30, 2008 at 12:35 PM, Rahul <unicorn_admirer at yahoo.com> wrote:
> Hi,
>          I think you are right as i also tried the same thing with the
> AutoDesk Mapguide Studio 2009 and MGOS2.0.1 and use to get the same error
> when selecting from search result, i was thinking to give a try with MGE2009
> otherwise log the defect with Autodesk.
> Max !
> ----- Original Message ----
> From: Shamrock Shooter <dan.allen at mrbgroup.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Saturday, June 28, 2008 2:37:38 AM
> Subject: Re: [mapguide-users] Fusion Error When Selecting From Search
> Results
> I have done everything in AutoDesk Mapguide Studio 2009, so I have done no
> custom programming at all.  If Studio 2009 is using the wrong viewer, then
> that sounds like a bug on their end.  Would what you suggest below still be
> relavant?
> ralph2008 wrote:
>> Hi Shamrock,
>> I think that you are using the Ajax API viewer instead of using theFusion
>> Viewer API.
>> The fusion viewer API is the "MapGuideViewerApi.js" and is located in:
>> "C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\MapGuide"
>> You must referencingt this file in your script and change the some lines
>> in your scripts:
>> for instances: change "parent.parent.refresh()" by "Refresh()"
>> I hope it help you
>> Regards,
>> Rodolfo M.
>> GIS Developer
>> Research & Development
>> Voxiva, Inc.
>> Shamrock Shooter wrote:
>>> I am running MOS 2.0.1 with AutoDesk Studio 2009.  I created a search
>>> button to lookup address from my tax parcels shapefile attribute data.
>>> If i run it in the basic layout it works fine.  If I run it in the fusion
>>> layout, it will populate a list of values in the task pane, but when I
>>> select one of the search results, it does not zoom to it in the map and
>>> throws me this error:
>>> Fusion Error:
>>> WARNING: Exception occurred in AJAX callback.
>>> SyntaxError: syntax error
>>> Location: undefined (737)
>>> xx)
>>> Can anyone help me out?  I tried some searching but didn't find any
>>> similar posts.
> http://www.nabble.com/Fusion-Error-When-Selecting-From-Search-Results-tp18161869p18162415.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
