[mapguide-users] [mapguide-announce] MapGuide Open Source 2.0.0released
Zac Spitzer zac.spitzer at gmail.com
Sat Mar 1 12:29:25 EST 2008
i just tried this out with a tiled raster comparing PNG to PNG8,
(135kb to 37kb) great stuff!
http://zacster.blogspot.com/2008/03/mapguide-20-released-png8-goodness.html
On Sat, Mar 1, 2008 at 4:10 AM, Trevor Wekel <trevor.wekel at autodesk.com> wrote:
> Yes.  In serverconfig.ini change "ImageFormat = PNG" to "ImageFormat = PNG8".  This will cause all tiles to be rendered and served as PNG8.
>  I will also update the ticket.
>  Thanks,
>  Trevor
>  -----Original Message-----
>  From: Jose Manuel C G [mailto:gis at mapas-sll.com]
>  Sent: Friday, February 29, 2008 3:30 AM
>  To: mapguide-users at lists.osgeo.org
>  Subject: Re: RE: [mapguide-users] [mapguide-announce] MapGuide Open Source 2.0.0released
>  > is there a way of enabling this for GETTILEDIMAGE?
>  Here I post the comment in the ticket who fix the problem:
>  Comment:
>   Fix submitted for 2.0.x stream in
>   http://trac.osgeo.org/mapguide/changeset/3028
>   and for trunk in http://trac.osgeo.org/mapguide/changeset/3029
>   Support for GIF has been fixed and PNG8 support has been implemented.  The
>   following formats will now work in ajaxmappane.templ:
>   PNG:  32 bit PNG with alpha
>   PNG8: 8 bit indexed color PNG with transparency support
>   GIF: 8 bit indexed color GIF with transparency support
>   JPG:  24 bit JPG image with no transparency
>   Also added experimental PNG8 tile support for 2.0.x stream
>   http://trac.osgeo.org/mapguide/changeset/3030 and trunk
>   http://trac.osgeo.org/mapguide/changeset/3031
>   Tiled images can now be rendered and served as:
>  View this message in context: http://www.nabble.com/MapGuide-Open-Source-2.0.0-released-tp15751970s16610p15755895.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>  _______________________________________________
>  mapguide-users mailing list
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
