[mapguide-users] MSSql and mapguide, data not displayed
Jackie Ng jackie.ng at aecsystems.com.au
Mon Mar 3 00:30:47 EST 2008
Did you define a spatial context (a coordinate system) for that ODBC feature
source? If so, is it the same one as the Sheboygan map?
- Jackie
deakaron wrote:
> I am trying to display features in mapguide using a resource that should
> read data from an MSSql table.
> the table SpatialData(Id int, Name nvarchar(50), x float, y float)
>  http://www.nabble.com/file/p15760131/mssql.jpg
> The table already contains two rows with coordinates that are inside the
> sample Sheboygan map, I use an OBDC connection, the Studio recignizes the
> geometric and other data fine as can be seen on the image, but if i try to
> preview nothing can be seen or selected no matter what scale settings I
> use.
> Here are my settings:
>  http://www.nabble.com/file/p15760131/mapguide.jpg
> any help would be appreciated
View this message in context: http://www.nabble.com/MSSql-and-mapguide%2C-data-not-displayed-tp15760131s16610p15798008.html
