[mapguide-users] Problems with mapagent in Mapguide OS version2onubuntu?
Jo Cook j.cook at OXFORDARCH.CO.UK
Tue Mar 4 04:21:27 EST 2008
Ace! Commenting out both lines:
AddHandler mgmapagent_handler fcgi and
LoadModule mgmapagent_module modules/mod_mgmapagent.so
 and restarting both mgserver and apache worked for me!
Many Thanks
Jo
Andy Morsell wrote:
> That line was commented out in mapguide.conf.  I uncommented it, restarted
> Linux and restarted Apache and I am still seeing the same problem.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
> Sent: Monday, March 03, 2008 12:14 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Problems with mapagent in Mapguide OS
> version2onubuntu?
> Can you check the mapguide.conf file found in
> /usr/local/mapguideopensource/webserverextensions/apache/conf and see if
> there is an occurrence of fcgi in there?  I think that there needs to be a
> line:
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Monday, March 03, 2008 10:48 AM
> To: 'MapGuide Users Mail List'
> version2
> onubuntu?
> Looks like it is sending you back the actual fcgi executable file. Not
> sure
> what the fix is...
> Traian
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of Andy Morsell
>> Sent: Monday, March 03, 2008 12:43 PM
>> version2 onubuntu?
>> Here's what I get in Fiddler from Studio or from any mapagent
>> operation from the web tier tests:
>> HTTP/1.1 200 OK
>> Date: Mon, 03 Mar 2008 09:37:31 GMT
>> Server: Apache/2.2.4 (Unix) DAV/2 PHP/5.2.1
>> Last-Modified: Mon, 03 Mar 2008 00:11:21 GMT
>> ETag: "28f04d-49088f-3a461c40"
>> Accept-Ranges: bytes
>> Content-Length: 4786319
>> Content-Type: text/plain
>> ELF
>> Andy
>> Stanev
>> Sent: Monday, March 03, 2008 9:34 AM
>> version2
>> onubuntu?
>> When connecting with Studio, run a tool like Fiddler, in order to
>> examine the exact response you are getting from the server. Studio is
>> probably swallowing some exception.
>> Traian
>> > Sent: Monday, March 03, 2008 12:16 PM
>> > version 2 onubuntu?
>> > I just got to the same point on CentOS 5 and am seeing the exact
>> > same problems.  MapGuide Server starts successfully, PHP and Apache
>> > are working.
>> > The PHP test page shows MapGuide API support.  I was also able to
>> > login to mapadmin and  successfully load the Sheboygan package.
>> > But, I cannot do anything involving the mapagent including any of
>> > the operations from the web tier tests and am prompted to download
>> > file type fcgi which looks to be ascii.  When trying to connect to
>> > the
>> site
>> > via Autodesk MapGuide Studio 2009, I get an "unexpected error in
>> > contacting site URL" error.
>> > I concur that the problem looks like it is mapagent related and I am
>> > unsure where to start trouble-shooting.  The big question is did
>> > mapagent not build properly, or is there a configuration problem?
>> > Jo, out of curiosity, did you find the configure / make / make
>> install
>> > to take an exorbitant amount of time?  I was finding that each step
>> in
>> > my case was taking about 6 hours.  I also ran into make problems the
>> > first time through and ended up doing a build_oem.sh --clean and
>> > then restarting the process.  After that, the install seemed to
> complete.
>> > Andy Morsell, P.E.
>> > Spatial Integrators, Inc.
>> > http://www.SpatialGIS.com
>> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jo Cook
>> > Sent: Monday, March 03, 2008 2:53 AM
>> > To: mapguide-users at lists.osgeo.org
>> > Subject: [mapguide-users] Problems with mapagent in Mapguide OS
>> version
>> > 2
>> > onubuntu?
>> > Hi,
>> > I resolved earlier problems by completely rebuilding my MGOS
>> > installation from scratch from the latest svn versions and it seemed
>> > to get all
>> the
>> > way
>> > through without failing. I have even managed to get the server to
>> run,
>> > which
>> > is a step forward. However, I am having problems with mapagent now,
>> > I think.
>> > What I can do:
>> > 1: Connect to mapadmin and load a package
>> > 2: Check the basic pages to ensure apache is working
>> > 3: Get to the mapagent pages
>> > What I can't do:
>> > 1: Connect using webstudio (times out) or mapguide studio
>> > (unexpected error contacting site URL), or fusion (times out
>> > displaying the sample
>> data)
>> > 2: Use mapagent in any way. When I try and use any of the options
>> like
>> > "Get
>> > Capabilities" I just get to download the mapagent.fcgi file, no xml
>> > document. The same thing happens when I try to use "Enumerate
>> > Reosources"
>> > from the URL as suggested in the documentation. If I try and open
>> > the fcgi file (in case it's actually an xml file but mis-named) it's
>> > gobbledegook.
>> > Neither the mgserver logs or apache logs appear to show anything
>> wrong,
>> > but
>> > I assume this is a problem with mapagent not building or running
>> > properly.
>> > I'm not really sure how to find out though.
>> > Any thoughts?
>> > Jo
>> > View this message in context:
>> > http://www.nabble.com/Problems-with-mapagent-in-Mapguide-OS-version-
>> 2-
>> > on-ubu
>> > ntu--tp15799952s16610p15799952.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Problems-with-mapagent-in-Mapguide-OS-version-2-on-ubuntu--tp15799952s16610p15823265.html
