[mapguide-users] Fusion Framework & UMN MapServer
Paul Spencer pagameba at gmail.com
Wed Mar 5 10:04:04 EST 2008
Hi Tim,
it can be but there is currently no official open source version of
fusion that works with mapserver.  We are currently in the process of
moving fusion to osgeo servers at which time a community can grow
around both mapguide and mapserver back-ends.
That being said, you can edit config.json in fusion to set the
appropriate values for your mapserver install and set up a map in the
application definition using MapServer as the type and give a MapFile
path in the extension ... something like:
   <MapSet xsi:type="MapSetType">
     <MapGroup id="gmap" xsi:type="MapType">
       <Map xsi:type="MapLayerType">
         <Type>MapServer</Type>
         <SingleTile>true</SingleTile>
         <Extension>
             <MapFile>/ms4w/apps/gmap/htdocs/gmap75.map</MapFile>
         </Extension>
       </Map>
     </MapGroup>
   </MapSet>
and then change the MapWidget tag to point to the id of the map group
(gmap in the above example) and it should all just work.  Note that
mapserver support requires that you have php_mapscript and a valid
session.save_path set up in php.ini
Also, the name of the php_mapscript module is hardcoded in fusion/
MapServer/php/Common.php so if you want something other than:
$szPHPMapScriptModule = 'php_mapscript.'.PHP_SHLIB_SUFFIX;
you will need to manually change it there for now.
Cheers
Paul
On 29-Feb-08, at 10:07 AM, Nolte, Tim wrote:
> Anybody have experience using the Fusion framework with the UMN
> MapServer. We currently have a UMN MapServer running and I'd really
> like
> to move to the Fusion framework, as I've heard it could be used with
> MapServer. I'd like as much information as possible to speed up my
> migration time. Thanks.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Paul Spencer
CTO, DM Solutions Group Inc
http://www.dmsolutions.ca/
