[mapguide-users] MGOS 2.0.0 Install failure
BradM masonb at dfo-mpo.gc.ca
Sun Mar 9 12:28:40 EDT 2008
Is the only solution to de-install Mapguide Enterprise totally?   We have an
active license and there are benefits to working with both MGOS 2.0 and MGE
on the same server if possible.
Jim O'Leary wrote:
> Now I have installed the release MGOS 2.0.0 and have the same problem:
> Apache cannot load MgHttpHandler.dll. Any suggestions?
> Thanks
> Ben Schalley wrote:
>> Jim O'Leary wrote:
>>> I have installed MapGuide Open Source 2.0.0 Beta 2 on Windows Server
>>> 2003. We also have MGE 2008 running on this machine.
>>> The MGOS web server does not start. When I manually try to start it, it
>>> says:
>>> httpd.exe: Syntax error on line 126 of C:/Program
>>> Files/MapGuideOpenSource2.0/We
>>> bServerExtensions/Apache2/conf/httpd.conf: Cannot load
>>> ../Php/MgHttpHandler.dll
>>> into server: The specified procedure could not be found.
>>> It is this line that causes the failure:
>>> LoadFile ../Php/MgHttpHandler.dll
>>> However, the MgHttpHandler.dll is there. The other DLLs appear to load.
>> Yesterday I installed MapGuide Open Source 2.0.0 RC3 on my development
>> machine, Windows XP Professional sp2, following the instructions
>> http://trac.osgeo.org/mapguide/wiki/InstallSideBySide1.2and2.0IIS for a
>> side by side install with MGOS 1.2 on IIS.
>> I have the same issue as described above by Jim O'Leary.
>> Anyone with an idea as how to solve this issue?
>> Thanks
View this message in context: http://www.nabble.com/MGOS-2.0.0-Beta-2-loadfile-error-tp14373978s16610p15943140.html
