[mapguide-users] Info: phpgenerictask theme -> xml error
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Mar 10 07:45:58 EDT 2008
It would be really great if you would create a Trac entry for this:
http://trac.osgeo.org/mapguide/
Regards, Kenneth, GEOGRAF A/S
web skrev:
> Hi all,
> For those who use the theme function of phpgenerictasks:
> Sometimes when creating a Theme, an exception occurs in:
> classes/theme.php method ApplyTheme():
> At this line:
> $resourceService->SetResource($layerResId, $byteSource->GetReader(),
> null);
> The error sounds like this:
> Error: XML Indexer: Parse error in document at line, 34, char 12.
> Parser message: Not enough elements to match content model :
> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
> So after browsing a little the web, I've seen a Post which fixes
> similar problems for pointrules..
> What needs to be done is:
> Adding a <SizeContext>DeviceUnits</SizeContext> tag in
> phpgenerictasks\theme\templates\arearuletemplate.xml
> Initially the file is like this:
> <AreaRule>
>  <LegendLabel>%s</LegendLabel>
>  <Filter>%s</Filter>
>  <AreaSymbolization2D>
>   <Fill>
>    <FillPattern>Solid</FillPattern>
>    <ForegroundColor>%s</ForegroundColor>
>    <BackgroundColor>FF000000</BackgroundColor>
>   </Fill>
>   <Stroke>
>    <LineStyle>Solid</LineStyle>
>    <Thickness>0</Thickness>
>    <Color>%s</Color>
>    <Unit>Inches</Unit>
>   </Stroke>
>  </AreaSymbolization2D>
> </AreaRule>
> and it might be changed like this:
> <AreaRule>
>  <Filter>%s</Filter>
>   <Fill>
>   </Fill>
>   <Stroke>
>    <Color>%s</Color>
>    <Unit>Inches</Unit>
>   * <SizeContext>DeviceUnits</SizeContext>*
>   </Stroke>
> </AreaRule>
> It solves my problem, hope this can help someone :-)
> Cheers, Rémy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080310/58fe04c3/attachment.html
