[mapguide-users] Firefox 3.0b3 and MapGuide - BUG
Dave Wilson dave.wilson at autodesk.com
Mon Mar 10 10:47:55 EDT 2008
We were seeing issues in the error logs BECAUSE of the use of AcceptEx as per the following link:
http://www.mydigitallife.info/2006/03/09/winnt_accept-asynchronous-acceptex-failed-error-in-apache-log/
As a result we implemented the disable call in the http.conf file to resolve the issues we were seeing. I'm not sure why this would be causing a problem.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, March 06, 2008 3:48 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Firefox 3.0b3 and MapGuide - BUG
Okay, my environment is Windows XP SP2 w/ MGOS 2.0.0 (Apache/PHP
configuration) and the Sheboygan dataset.
My preliminary findings so far:
- The following POST request fails (it was the only error visible in
firebug)
OPERATION=GETVISIBLEMAPEXTENT&VERSION=1.0.0&SESSION=1eef8b10-0000-1000-8001-000c292b5017_en_7F0000010AFC0AFB0AFA&MAPNAME=Sheboygan&SEQ=0.8608854176114282&SETDISPLAYDPI=96&SETDISPLAYWIDTH=824&SETDISPLAYHEIGHT=453&SETVIEWSCALE=98563.34333416916&SETVIEWCENTERX=-87.7302542509315&SETVIEWCENTERY=43.744459064634
- That POST request also happens to kill/crash my Apache service everytime
(!!!), looking at my error logs I see the following message:
The Apache service named  reported the following error:
>>> [Fri Mar 07 09:53:44 2008] [notice] Disabled use of AcceptEx() WinSock2
>>> API     .
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
- Jackie
Jackie Ng wrote:
> Hmm, I didn't think firebug was compatible w/ ff3, but it seems the latest
> beta does. Gotta do some investigating :)
> - Jackie
> Tom Fukushima wrote:
>> If you (i.e., anyone in the MGOS community running FF 3.0b3) install the
>> Firebug FF addon, you should be able to debug and potentially fix this.
>> If you do, please supply a patch to the ticket
>> (http://trac.osgeo.org/mapguide/ticket/378) that Jackie had mentioned.
>> Or if you are not sure what the fix is, even the errors that firebug
>> displays might be helpful.
>> Thanks
>> Tom
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
>> Skorczewski
>> Sent: Thursday, March 06, 2008 5:28 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Firefox 3.0b3 and MapGuide - BUG
>> hi Paul!
>> I see that new Firefox 3 works whit fusion fine...but there are many of
>> MG 1.2 aplication that will don't work whit this browser release. :(
>> i my aopinion it is bug in javascript ...Firefox 3 is more closely
>> following the javascript spec.
>> so can we fix this? any idea?
>> macieks
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Firefox-3.0b3-and-MapGuide---BUG-tp15871580s16610p15885377.html
