[mapguide-users] Lable problem
Traian Stanev traian.stanev at autodesk.com
Mon Mar 10 11:15:44 EDT 2008
I think he means the text is appearing left-to-right, rather than the correct right-to-left. There is a ticket for that one (#271) and the solution is to implement a bidirectional reordering algorithm. I have such an algorithm, but so far have not had time to attempt to integrate it. Like someone else mentioned, there is a workaround, which involves storing the label strings in reverse in the data source.
Now that I think of it, it may be best to implement reordering as a custom expression function that one can use to reorder text. This way, no code changes would be needed apart from the implementation of that custom function.
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, March 10, 2008 10:51 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Lable problem
Does the font you are using exist on the server machine? If not the server will not be able to render it in the AJAX Viewer.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ????? ???
Sent: Sunday, March 09, 2008 3:48 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Lable problem
Im trying to set a hebrew lable for a layer, but in any font i try to set it in studio it does not show it corectly, can any one help me?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080310/8310a059/attachment.html
