[mapguide-users] Problems with SDF/Database Joins (Oracle)
Zac Spitzer zac.spitzer at gmail.com
Tue Mar 11 18:59:09 EDT 2008
you can just 'touch' the datasource to force a refresh of the cached schema
just get the XML resourceContent and overwrite the existing featureSource
On Wed, Mar 12, 2008 at 3:13 AM, Bruce Dechant
<bruce.dechant at autodesk.com> wrote:
> Jackie,
>  If you want to disable FDO caching for a specific provider you can do the following:
>  In the serverconfig.ini file edit the DataConnectionPoolExcludedProviders parameter. Example below: (disables it for ODBC and MySql)
>  DataConnectionPoolExcludedProviders = OSGeo.ODBC,OSGeo.MySQL
>  If you want to disable it for all providers you can do the following:
>  DataConnectionPoolEnabled = 0
>  Warning: Doing this does impact performance, especially for RDBMS (Oracle, etc...)
>  Note: The SDF and SHP providers are already excluded from the data connection pooling because of a FDO defect, but even though they are excluded they are still fast.
>  Thanks,
>  Bruce
>  -----Original Message-----
>  From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>  Sent: Monday, March 10, 2008 10:40 PM
>  To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Problems with SDF/Database Joins (Oracle)
>  Hi Bruce,
>  I too find this "problem" annoying during the development/testing stages, as
>  our db schemas are in flux. Having to restart mapguide everytime the db
>  changes is time consuming.
>  So how would I go about disabling caching on a per-provider level?
>  - Jackie
>  Bruce Dechant wrote:
>  > Max,
>  > This is related to the caching done by the MapGuide server, but is not a
>  > defect.
>  > The problem is that the MapGuide server has no idea that the underlying
>  > feature source schema changed. There is no callback from Oracle (or any
>  > other provider) to FDO and then finally to the MapGuide server to inform
>  > about any schema changes.
>  > If you are going to be making schema changes while you are developing your
>  > site then you could temporarily disable the caching of the specific FDO
>  > provider you are using. This will also disable the caching of the
>  > underlying schemas and classes. Then turn it back on once your schema
>  > changes are done.
>  > Alternatively, you can disable the caching of all schemas and classes by
>  > setting the "CacheSize" parameter in the serverconfig.ini file to 0. Be
>  > warned that by doing this the MapGuide server will be MUCH slower because
>  > it will have to get this information from the underlying FDO providers for
>  > everything it does.
>  > I can see adding an API to MapGuide that you can call to clear the FDO
>  > schema/classes cache being useful in this case. The WebAdmin could be
>  > updated to call this to clear the cache without stopping the MapGuide
>  > server whenever you made changes to your schemas.
>  > Thanks,
>  > Bruce
>  > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bob Cassarly
>  > Sent: Sunday, March 09, 2008 3:06 PM
>  > Subject: Re: [mapguide-users] Problems with SDF/Database Joins (Oracle)
>  > Max,
>  > That is the driver I was using from my DSN.
>  > My problem appears to be a problem is with the way MapGuide OS is caching
>  > the database table/columns
>  > If you first create a new Data Connection that uses a DSN (that uses the
>  > Oracle Instant Client 10.2.0.3) it does indeed work and the tables
>  > enumerate.  The problem I noticed with this is that if you change a table
>  > or
>  > view definition to add a table/view column the new column does not appear
>  > in
>  > the label/theme list.  This seems like a bug to me (especially considering
>  > there does not seem to be a mechanism to update the cache).
>  > If create a Data Source that uses the FDO ODBC Microsoft for Oracle driver
>  > it connect sucessfully to the database but the tables do not enumerate.
>  > If
>  > I save that Data Connection as then later change Data Connection to use a
>  > DSN the tables do not enumerate.  This also seems like a bug to me.
>  > So the question is where are the database tables/columns cached too and is
>  > it possible to refresh the cache.  Personally I would prefer that the
>  > table/column NOT be cached at all but maybe I am asking too much.
>  > Bob
>  > Hi,
>  >         I think you try to connect Oracle Database  with Oracle Instant
>  > Client 10.2.0.3 and  oracle odbc driver-win32 10.2.0.3 .
>  > Try ODBC FDO "Connect via a Data Source Name (DSN) set up on this server"
>  > and use the above DSN which you created using the oracle odbc driver-win32
>  > 10.2.0.3 .
>  > Max !!
>  > View this message in context:
>  > http://www.nabble.com/Problems-with-SDF-Database-Joins-%28Oracle%29-tp15906732s16610p15946485.html
>  > Sent from the MapGuide Users mailing list archive at Nabble.com.
>  > _______________________________________________
>  > mapguide-users mailing list
>  > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>  View this message in context: http://www.nabble.com/Problems-with-SDF-Database-Joins-%28Oracle%29-tp15906732s16610p15974750.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
