[mapguide-users] deleting feature source
Jackie Ng jackie.ng at aecsystems.com.au
Mon Mar 17 22:14:15 EDT 2008
Just to clarify, is this a shared feature source for temporary features? You
want other user's to see temporary features inserted by all users?
What you could try to do is alter the feature class to include an extra
property: User
When a user adds a temporary marker to the map, include that user's id as
part of the new feature.
You can then hook onto the onunload javascript event to invoke a server-side
script to remove all features from that feature source where the [User] is
the ID of the user who just closed the web app.
Hope that helps.
- Jackie
Kencana wrote:
> Hi all,
> Is that possible to delete the feature source when user leave the map web
> app?
> Previously, I used one feature source to draw the temporary layer, however
> when there are more than 1 user using the map application at the same
> time, the marker will be either missing or it is pointed to another
> location. therefore, i decided to create one unique feature source for
> each user who visits the map app. it solves the missing marker issue, but
> i believe it is not the correct solution for this, as it keeps create new
> feature source it will take more server storage. Any idea for solving this
> problem?
> Thank you
> Regards,
> Kencana Kesuma
View this message in context: http://www.nabble.com/deleting-feature-source-tp16112200s16610p16112368.html
