[mapguide-users] DB XML Component Error in Dynamic Theming
Rahul unicorn_admirer at yahoo.com
Tue Mar 18 11:45:39 EDT 2008
Hi ,
      Thanks for your reply,i am using MGOS 1.2.0 ,yeh the exception shows that not enough elements to match content model , Anyway i will try to stylize the layer using the mapguide studio and  capture the xml output but what i use for the validation of the LayerDefinition document.
Thks
Max
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Monday, March 17, 2008 10:25:43 PM
Subject: Re: [mapguide-users] DB XML Component Error in Dynamic Theming
It sounds like the layer definition xml does not validate. Are you able to
capture the xml output of the theme layer and see if it is a valid
LayerDefinition document?
Also, what version of MapGuide are you using?
- Jackie
max_samart wrote:
> Hi All,
>          I have some sdf files as Polygons and when i want to use the
> Dynamic Theming(GT Example), its use to give  mgdbxmlexception error,
> although I can do dynamic theming on some other sdf layers in the map but
> on some layers i am getting exception with pid terminated with exit
> status'0' .Can anybody give some idea reagarding the same in order to
> proceed further .
> Thks
> Max !!
> ERROR IN THE MAPGUIDE SERVER
> <2008-03-18T14:43:57>    Officer Error: An exception occurred in DB XML
> component.
> Error: XML Indexer:  Parse error in document at line, 61, char 12. Parser
> message:
> Not enough elements to match content model
> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
>  StackTrace:
>  - MgResourceServiceHandler.ProcessOperation line 80 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>  - MgOpSetResource.Execute line 109 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\OpSetResource.cpp
>  - MgServerResourceService.SetResource line 728 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ServerResourceService.cpp
>  - MgRepositoryManager.SetResource line 867 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\RepositoryManager.cpp
>  - MgRepositoryManager.AddResource line 840 file
>  - MgResourceContentManager.AddResource line 183 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>  - MgResourceContentManager.PutDocument line 624 file
>  - MgResourceDefinitionManager.PutDocument line 554 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> An exception occurred in DB XML component.
> message: Not enough elements to match content model :
> ERROR in the WebServer-
> [Tue Mar 18 14:43:20 2008] [warn] FastCGI: (dynamic) server "D:/Program
> Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
> (pid 4088) terminated with exit with status '0'
> [Tue Mar 18 14:43:37 2008] [error] [client 10.0.y.y] FastCGI: server
> "D:/Program Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe"
> stderr: PHP Fatal error:  Uncaught exception 'mgdbxmlexception' in Unknown
> on line 0, referer:
> http://10.0.x.x:8008/mapguide/Officers/theme/thememain.php
> [Tue Mar 18 14:43:57 2008] [error] [client 10.0.z.z] FastCGI: server
> on line 0, referer:
> ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
> mapguide-users mailing list
View this message in context: http://www.nabble.com/DB-XML-Component-Error-in-Dynamic-Theming-tp16117523s16610p16118026.html
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080318/4e734163/attachment.html
