[mapguide-users] Mapguide and consuming WFS: does it work for someone ?
Rahul unicorn_admirer at yahoo.com
Thu Mar 20 22:34:43 EDT 2008
Hi ,
         I think this is sort of bug and infact if you tried the MapGuide Server(MGOS 1.2.0) as WFS and try to publish some layers as WFS , you will get the same problem.I already logged this issue to the Autodesk but haven't  got any solution till now.
Similarly have you tried to get some Raster Imagery as WMS layers from Image Web Server into the MapGuide -1.2.0 & MGS 2008,Try this url http://www.earthetc.com/ecwp/ecw_wms.dll? ,you will be able to make sucessfull connection but unable to view any layer, i already posted this issue to the forum but till now haven't got any reply.
The above WMS Issue got solved in the Map 3D 2009 as well as MGE2009 but i am not sure about MGOS2.0.
Thanks
Max
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Thursday, March 20, 2008 9:56:00 PM
Subject: [mapguide-users] Mapguide and consuming WFS: does it work for someone ?
Hello,
I am using MGOS 1.2 and trying to consume WFS from following server:
http://www.gegis.org/gegis-1.2/wfs?
Although the layers and attributes are shown correctly in Mapguide Studio I
am not able to show the geometry. In the error.log there is following error
message:
  Error: Failed to stylize layer: LayerDefinition3
        An exception occurred in FDO component.
        Schema can not be found in the collection.
In order to check if it might be a problem with the WFS server itself, I
have tried some other servers on the Internet too. But result is always the
same, no geometry is shown ...
Is this a result of GML inconsistencies ?
Can someone point me in the right direction what should be done to get the
connection working ?
Thanks in advance.
View this message in context: http://www.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-someone---tp16180546s16610p16180546.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080320/b7926033/attachment.html
