[mapguide-users] Spatial filter visibility
Dave Wilson dave.wilson at autodesk.com
Thu Mar 27 10:25:39 EDT 2008
Not knowing the exact lines of code, you might want to install another copy of the web tier someplace else and do a file compare. That way if you ever upgrade you will know what you customized.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Luis Baptista
Sent: Thursday, March 27, 2008 3:58 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Spatial filter visibility
Hi all,
I think this is a simple question but I already lost a lot of time with it.
I'm using WIndows2003 Server with MGE2008, developping in C#.
When we use the Query Spatial Filters, we draw a rectangle or polygon and those use to appear marked as red (red border with some red transparency as background.
Since I was changing the color templates (probably is because of this, I don't know), everytime I draw a spatial filter I can't see it, there is no border or foreground color. The filter is there and return the  correct results but it's impossible to see.
Can someone help me and tell me where do I define the colours or the visibility on/off for spatial filters?
At the same time, when I draw a spatial filter or start measuring, appears a new entry in the layers legend.
Now I only get a new entry for measuring, spatial filter is invisible in the map window and do not show as new entry in the layers legend.
Thanks for any help I already spent too much time with this
Luis
Discover the new Windows Vista Learn more!<http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080327/7d009530/attachment.html
