[mapguide-users] Fusion with jsp
Jackie Ng jackie.ng at aecsystems.com.au
Fri Mar 28 10:36:48 EDT 2008
The PHP part of Fusion is the server-side functionality required by some
Fusion components/widgets. No JSP or .net implementation exists (yet)
- Jackie
abdrabba yassine wrote:
> Hi,
> I'm developing a web application with mapguide using the JAVA Web
> extensions
> API, and for the viewer i want to use the Fusion Viewer.
> My question is how i can implement functionality that requires direct
> access
> to the MapGuide Server. Because as I know the additional functionality is
> implemented only in PHP on top of the MapGuide Web Tier API.
> Could anyone tell me where I can find a JSP implementation.
> thank you in advance.
> Abdrabba Yassine
> Blog: http://a-yassine.blogspot.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Fusion-with-jsp-tp16349934s16610p16350321.html
