[mapguide-users] Please try your operation later as the resource was busy
Zac Spitzer zac.spitzer at gmail.com
Mon Mar 31 03:14:38 EDT 2008
Are you closing your featureReader? show us some more code :)
Also, you probably want to be using session resources rather than
library resources
On Mon, Mar 31, 2008 at 6:08 PM, adman666 <adam at aemsaustralia.com.au> wrote:
>  Hi,
>  We are having problems since upgrading to MGOS2.
>  Our app creates FeatureSources on the fly as a user needs them:
>  featureService.CreateFeatureSource(markupSdfResId, sdfParams)
>  and then they can draw on the layer and the Feature Source is updated:
>  featureService.UpdateFeatures(resourceIdentifier, markupCommands, False)
>  This was all good under 1.2. The Resources are not ReadOnly. When we execute
>  the code now we get this error:
>  <2008-03-31T16:49:32>                   Administrator
>   Error: Please try your operation later as the resource was busy:
>  Library://AEMSDB/Actions/487/Data/11504.FeatureSource
>   StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpUpdateFeatures.Execute line 111 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
>   - MgServerUpdateFeatures.UpdateFeatures line 131 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
>   - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
>  We have never seen this before upgrading to 2.0. Do we need to set some
>  extra permissions somewhere or something like that?
>  Any ideas would be most appreciated.
>  Thanks.
>  View this message in context: http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736s16610p16392736.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>  _______________________________________________
>  mapguide-users mailing list
>  mapguide-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
