[mapguide-users] Determine if Layer is a Raster Layer
Jackie C. Ng jumpinjackie at gmail.com
Tue May 6 11:02:54 EDT 2008
Look at the xml content of the layer definition.
Raster layers have the root element of GridLayerDefinition
Vector layers have the root element of VectorLayerDefinition
- Jackie
Adnan Chughtai wrote:
> Hello All,
> Currently working with the API for MapGuide OpenSource 2.0 and have an
> issue with determining with a Layer is a Raster Layer.  I am using the
> OSGeo FDO Provider for Raster
> In MapGuide 6 - the method getLayerType() returned a string denoting the
> layer type, e.g Polyline, Polygon, Raster, etc.
> In MGOS 2.0, the method getLayerType() returns an int with two possible
> values 2 -Basemap or 1 - Dynamic.  Is there a method in MGOS 2.0 API that
> does a similar function as the getLayerType which is in MapGuide 6?
> Regards,
> Adnan
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Determine-if-Layer-is-a-Raster-Layer-tp17084050p17084856.html
