[mapguide-users] query question
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed May 7 15:59:31 EDT 2008
Not from me - but I'd imagine that people will need to see your custom
query script in order to help....
David Nuell wrote:
> Thanks for the suggestion Andrew.  I appreciate the response.  I had a look
> at the search command, and like you say - it is pretty limited.  I'm hoping
> to get the 'robustness' of the query to work so that users can query
> anything they want.
> Any other suggestions?
> andrew.demerchant wrote:
>> Not sure that I can be of help with this specifically, but I do know
>> that there is a built-in search command, and it works fine. Maybe it
>> would do the trick? It may be too limited for you though - only one
>> field can be searched...
>> Andrew
>> David Nuell wrote:
>>> Hi all - I am going to repost this in hopes that someone can help.
>>> Cheers!
>>> (see original post)
>>> David Nuell wrote:
>>>> Hi Listers -
>>>> I am having some troubles with a query function and I hope that someone
>>>> out there can help.
>>>> - I have a map built via MapGuide Studio
>>>> - I have created a new command called 'Query'
>>>> - I have enter the exact same information into the settings of the query
>>>> command as in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
>>>> - save my web layout and open it in an AJAX viewer (and/or DWF viewer)
>>>> - select the query command and it opens in the side window (right pane)
>>>> - I can select a layer that is in my layers list along with everything
>>>> else to query the data including the output property.
>>>> As soon as I hit execute, nothing shows up in the results panel...
>>>> What am I missing? Any ideas?
>>>> Thanks (again).
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
