[mapguide-users] MapGuide Selection and UniqueID Determination
Berdel, Brian brian.berdel at mcmtrans.com
Thu May 8 10:19:34 EDT 2008
That is what I thought...Thanks, I'll look into into it further.
-Brian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Thursday, May 08, 2008 9:04 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Selection and UniqueID
Determination
It should be enough to call SetSelectionXml.
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
I have a quick question about selection as well...If I have the
selection XML can I just call the Javascript Function setSelection, or
do I have to do the code in the code behind for it to work? Basically I
have tried itand it does display that a selection has been made in the
panel and the status bar, but the map is not updated, even after a
refresh...
-Thanks
Brian
-----Original Message-----
GEOGRAF A/S
Sent: Thursday, May 08, 2008 2:56 AM
Determination
To be able to select items the layer must be selectable (set in the
MapDefinition).
Secondly, the FeatureSource must have at least one identity column.
If not, all features on the layer are selected.
Crispin @ 1Spatial skrev:
	Can someone explain how the magic of MapGuide selection works...
	Of particular interest to me is a particular ArcSDE dataset that
appears
	fine in MapGuide but (despite correct settings in Studio) has a
class
of
	points which when mapped as a layer do not 'select' in the map.
	Using a seperate direct FDO connection I can see the class has
no
	columns/proprttydefinitions that are "IsAutogenerated()" - is
this a
	requirement for a layer to be selectable or is there another
criteria?
	Tooltips appear OK.
	 Crispin
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080508/4b164305/attachment.html
