[mapguide-users] libOGRProvider.so
Jackie C. Ng jumpinjackie at gmail.com
Mon May 12 10:59:09 EDT 2008
If you called the GetFeatureProviders method from the mapagent test pages, is
there an entry for OSGeo.OGR in the xml content and if so, does it have the
expected connection properties?
- Jackie
schwanzy wrote:
> Hi,
>     now MapGuide OS 1.2 (with FDO 3.2.3) runs fine in Debian Etch i386.
> I built OGR FDO provider using  fdoogr-3.3.0.tar.gz (I cannot find
> fdoogr-3.2.3.tar.gz on fdo.osgeo.org):
>     g++ -fPIC --shared OgrFdoUtil.cpp OgrProvider.cpp
> -I/usr/local/fdo-3.2.3/include -I/usr/local/mapguideopensource/include
> -L/usr/local/fdo-3.2.3/lib -lFDO  -L/usr/local/mapguideopensource/lib
> -lgdal -o libOGRProvider.so
>     cp libOGRProvider.so /usr/local/fdo-3.2.3/lib
> and added provider definition to /usr/local/fdo-3.2.3/lib/providers.xml,
> but when I try to create a new data connection there's no way to specify
> connection settings as you can see from the attached image.
> Any clue?
> // Simone
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/libOGRProvider.so-tp17188741p17189307.html
