[mapguide-users] MrSID not working with 2.0?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri May 16 08:34:52 EDT 2008
Just out of curiosity, is there a way to use the old raster provider
(from MGOS 1.x) under 2.x? I've tried copying the dll and modifying the
providers.xml, but I think that I must have to register the dll in
windows somehow, because I got an invalid entry point msg (on the
server) when I tried to use it. Why did that provider get removed from
the 2.x release anyway? I know that it was an Autodesk provider and
all....did they just "lend" it to the 1.x open source release, under the
condition that it be removed for the 2.x branch?
Andrew
Dave Wilson wrote:
> Just something to eliminate but often people in their feature sources depending on the raster format are not ensuring a coordinate system is defined on the feature source. This is important and is required, it's possible this could cause some problems.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
> Sent: Thursday, May 15, 2008 1:06 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MrSID not working with 2.0?
> I am able to show MrSid files with MGOS 2.0, but from time to time I get
> server crashes. The log files are indicating something went wrong with
> stylization of the layer, but I could not find any pattern in the crashes.
> Therefore I disabled the raster layers. Looking on the forum there are a lot
> of people encountering similar problems with raster files.
> Rock Beans wrote:
>> That makes me cry a little. Well if I come up with anything I will post
>> back. Any other info from the top dogs would be great!
>> Thanks
>> The Rock
>> On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
>> andrew.demerchant at gemtec.ca> wrote:
>>>  No luck here....I've had success with other formats though. I filed a
>>> trac about my mrsid problem a month ago (or so).
>>> Rock Beans wrote:
>>> I followed the directions on the
>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0 pages.
>>> I
>>> am not getting any to work. I have not tested any other formats yet. Has
>>> anyone had luck with this or is there an update to the GDAL?
>>> The Rock
>>> mapguide-users mailing
>>> listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>     *Andrew DeMerchant*
>>>  *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> *GEMTEC Limited <http://www.gemtec.ca>
>>> *191 Doak Road
>>> Fredericton, NB, Canada
>>>  E3C 2E6
>>> mapguide-users mailing list
> View this message in context: http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
	*Andrew DeMerchant*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
