[mapguide-users] MrSID not working with 2.0?
Berdel, Brian brian.berdel at mcmtrans.com
Fri May 16 13:43:42 EDT 2008
That is what did the trick for me before. You can check the log files to
see if that is the issue.
Brian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Friday, May 16, 2008 11:55 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MrSID not working with 2.0?
I did find the override cord system in studio not sure why I did not see
it before. I will try this and report back.
Thanks!
The Rock
On Fri, May 16, 2008 at 10:45 AM, Dave Wilson <dave.wilson at autodesk.com>
wrote:
Using MapGuide Studio and configuring Raster via an unmanaged connection
with the Autodesk provider there is the SupplementalSpatialContextInfo
as shown below in the feature source definition:
  <?xml version="1.0" encoding="utf-8" ?>
- <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>Autodesk.Raster</Provider>
- <Parameter>
  <Name>DefaultRasterFileLocation</Name>
<Value>%MG_DATA_PATH_ALIAS[Cal_GBU_QA_Data]%Raster/SanFran-UTM27-10/jpg/
</Value>
  </Parameter>
- <SupplementalSpatialContextInfo>
  <Name>Default</Name>
<CoordinateSystem>PROJCS["UTM27-10",GEOGCS["LL27",DATUM["NAD27",SPHEROID
["CLRK66",6378206.400,294.97869821]],PRIMEM["Greenwich",0],UNIT["Degree"
,0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["fal
se_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER["cen
tral_meridian",-123.00000000000000],PARAMETER["scale_factor",0.9996],PAR
AMETER["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]</Coor
dinateSystem>
  </SupplementalSpatialContextInfo>
  <ConfigurationDocument>config.xml</ConfigurationDocument>
</FeatureSource>
I'm not sure how the feature source looks for the Open Source provider,
but I'd be surprised there isn't an equivalent element available in the
schema.
Dave
Sent: Friday, May 16, 2008 9:32 AM
In a raster based feature source there is no where to override a cord
system so can you please explain?
On Thu, May 15, 2008 at 2:24 PM, Dave Wilson <dave.wilson at autodesk.com>
wrote:
Just something to eliminate but often people in their feature sources
depending on the raster format are not ensuring a coordinate system is
defined on the feature source. This is important and is required, it's
possible this could cause some problems.
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
Sent: Thursday, May 15, 2008 1:06 PM
To: mapguide-users at lists.osgeo.org
I am able to show MrSid files with MGOS 2.0, but from time to time I get
server crashes. The log files are indicating something went wrong with
stylization of the layer, but I could not find any pattern in the
crashes.
Therefore I disabled the raster layers. Looking on the forum there are a
lot
of people encountering similar problems with raster files.
Rock Beans wrote:
> That makes me cry a little. Well if I come up with anything I will
post
> back. Any other info from the top dogs would be great!
> Thanks
> The Rock
> On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
> andrew.demerchant at gemtec.ca> wrote:
>>  No luck here....I've had success with other formats though. I filed
a
>> trac about my mrsid problem a month ago (or so).
>> Rock Beans wrote:
>> I followed the directions on the
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0
pages.
>> I
>> am not getting any to work. I have not tested any other formats yet.
Has
>> anyone had luck with this or is there an update to the GDAL?
>> The Rock
>> mapguide-users mailing
listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinf
o/mapguide-users
>>     *Andrew DeMerchant*
>>  *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> *GEMTEC Limited <http://www.gemtec.ca>
>> *191 Doak Road
>> Fredericton, NB, Canada
>>  E3C 2E6
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context:
http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.ht
ml
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080516/1d488b33/attachment.html
