[mapguide-users] Update Line Feature Class
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 21 05:59:30 EDT 2008
Hello Akram.
What you do here, is essentially copy a map's xml definition. Your step
1 is the same as calling resourceService.CopyResource(layerDefResId,
layerDefId).
I can't see where your "newLayer" variable comes from (the one you insert).
If you already have a layer, it is much easier to include it in the map,
but keep it invisible. Then turn it on when you want to display it. That
would remove step 1 and 2.
You only have to create a copy of the layer if you want to modify it for
the current session. If you want the layer to display another feature
source, you must update the xml in step 1.
Step 3 looks OK.
In step 4, I think you have used the id of the layerdefinition, rather
than the id of the featuresource. I am not sure you can do that.
If step 3 and 4 are completed, a refresh of the map should display your
new feature.
Perhaps the coordinates are misplaced, so the feature is inserted
outside the map?
If you have access to MapGuide Studio, you can preview your feature
source, and see the actual data rows.
With that, you can verify that there is an added row.
Regards, Kenneth Skovhede, GEOGRAF A/S
akram skrev:
> Hi Kenneth, Hi All,
> I would like to create new Line (MgFeatureGeometricType.Curve) Layer ,
> and create line feature in this new Layer , I worked with follwoing
> steps:
> 1.Take Layer Definition for Exsisting Line Layer and SetResource as
> following
> MgByteReader byteReader =
> resourceService.GetResourceContent(layerDefResId); XmlDocument doc =
> new XmlDocument(); String xmlLayerDef = byteReader.ToString();
> doc.LoadXml(xmlLayerDef); String xmlString =
> doc.DocumentElement.OuterXml; MgResourceIdentifier layerDefId = new
> MgResourceIdentifier("Session:" + GetParameter(this.args, "SESSION") +
> "//NewLayer.LayerDefinition"); resourceService.SetResource(layerDefId,
> new MgByteReader(xmlString, "text/xml"), null);
> 2. Insert New Layer
> layers.Insert(layers.IndexOf(layer), newLayer);
> 3.Create Line Geometry
> MgLinearRing Line = geometryFactory.CreateLinearRing(coordinateColl);
> MgGeometry Geom = geometryFactory.CreatePolygon(Line, null);
> 4.Write Geometry and Update Featur Service
> propertyValues.Add(new MgGeometryProperty("Geometry", byteReader1));
> updateCommands.Add(new MgInsertFeatures(className, propertyValues));
> MgFeatureService featureService =
> (MgFeatureService)this.site.CreateService(MgServiceType.FeatureService);
> featureService.UpdateFeatures(layerResId, updateCommands, false);
> 5. Save map and refresh
> after previouse steps No thing appear , No bugs , No Result , Only
> NewLayer Created
> Can you help me plz to update Exsisting Line Layer ?
> Best Regards
> Akram
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080521/c0af478b/attachment.html
