[mapguide-users] Problems of building fdo-3.3.0
Jack Lee jack.lee at autodesk.com
Tue May 27 06:52:44 EDT 2008
This output is building /usr/src/mapguide/FDO/OpenSource_FDO/Providers. Do you have the output for
/usr/src/mapguide/FDO/OpenSource_FDO/Fdo?
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dorin
Sent: Tuesday, May 27, 2008 4:27 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Problems of building fdo-3.3.0
I describe down the most of part of the error received durring the execution of build_linux.sh script:
Making all in Src
make[1]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src'
Making all in Message
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src/Message'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src/Message'
Making all in Provider
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src/Provider'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src/Provider'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src'
make[2]: *** No rule to make target `/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la', needed by `libWFSProvider.la'.  Stop.
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src'
make: *** [all-recursive] Error 1
Making install in Src
Making install in Message
Making install in Provider
make[3]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src/Provider'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WFS/Src/Provider'
make[1]: *** [install-recursive] Error 1
make: *** [install-recursive] Error 1
acinclude.m4:7: warning: underquoted definition of FDO_HELP_STRING
  run info '(automake)Extending aclocal'
  or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
acinclude.m4:12: warning: underquoted definition of FDO_SUBST
acinclude.m4:19: warning: underquoted definition of FDO_FAST_OUTPUT
acinclude.m4:25: warning: underquoted definition of FDO_GEN_CONFIG_VARS
acinclude.m4:66: warning: underquoted definition of FDO_GENERATE_MAKEFILES
acinclude.m4:73: warning: underquoted definition of FDO_OUTPUT
acinclude.m4:82: warning: underquoted definition of FDO_DEFINE_TYPE_RLIM_T
acinclude.m4:107: warning: underquoted definition of FDO_SUBST_EXPANDED_ARG
acinclude.m4:114: warning: underquoted definition of FDO_EXPORT_ARGUMENTS
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for bison... no
checking for byacc... no
checking build system type... x86_64-suse-linux
checking host system type... x86_64-suse-linux
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/x86_64-suse-linux/bin/ld
checking if the linker (/usr/x86_64-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/x86_64-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... cat: /etc/ld.so.conf.d/*.conf: No such file or directory
GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/x86_64-suse-linux/bin/ld -m elf_x86_64
checking if the linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
GNU/Linux ld.so
appending configuration tag "F77" to libtool
configure: Building with default location of FDO API files at /usr/src/mapguide/FDO/OpenSource_FDO/Fdo
configure: Building with default location of FDO Utility files at /usr/src/mapguide/FDO/OpenSource_FDO/Utilities
configure: Building with default location of FDO Thirdparty files at /usr/src/mapguide/FDO/OpenSource_FDO/Thirdparty
configure: Building with default location of thirdparty GDAL files at /usr/src/mapguide/FDO/OpenSource_FDO/Thirdparty/gdal
configure: Using optimized configuration
configure: creating ./config.status
config.status: creating Makefile
config.status: creating Src/Makefile
config.status: creating Inc/Makefile
config.status: creating Src/Message/Makefile
config.status: creating Src/Overrides/Makefile
config.status: creating Src/Provider/Makefile
config.status: creating Src/UnitTest/Makefile
config.status: creating Docs/Makefile
config.status: creating Docs/doc_src/Makefile
config.status: creating Docs/doc_src/group_and_page_definitions/Makefile
config.status: creating Docs/doc_src/headers_and_footers/Makefile
config.status: executing depfiles commands
Making all in Src
make[1]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Message'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Message'
Making all in Overrides
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Overrides'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Overrides'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Provider'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Provider'
Making all in UnitTest
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/UnitTest'
make[2]: *** No rule to make target `/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la', needed by `UnitTest'.  Stop.
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/UnitTest'
make[1]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src'
Making install in Overrides
make[3]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Overrides'
make[3]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Overrides'
make[3]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Provider'
make[3]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/WMS/Src/Provider'
Making install in UnitTest
GNU/Linux ld.so
GNU/Linux ld.so
Making all in Src
make[1]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Message'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Message'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
make[1]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src'
make[3]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[3]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[3]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[3]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/GDAL/Src/Provider'
Putting files in AC_CONFIG_AUX_DIR, `../..'.
GNU/Linux ld.so
GNU/Linux ld.so
make: *** No rule to make target `../../Fdo/Unmanaged/Src/libFDO.la', needed by `libOGRProvider.la'.  Stop.
linux-n5su:/usr/src/mapguide/FDO/OpenSource_FDO # linux-n5su:/usr/src/mapguide/FDO/OpenSource_FDO # ./libtool
*** Warning: inferring the mode of operation is deprecated.
*** Future versions of Libtool will require --mode=MODE be specified.
libtool: warning: cannot infer operation mode without MODE-ARGS
libtool: you must specify a MODE
Try `libtool --help' for more information.
linux-n5su:/usr/src/mapguide/FDO/OpenSource_FDO # ./build_linux.sh
configuring fdocore
checking whether build environment is sane...  cd . && /bin/sh ./config.status Makefile
Making all in Src
make[1]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src'
 cd .. && /bin/sh ./config.status Src/Makefile depfiles
make[1]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Message'
 cd ../.. && /bin/sh ./config.status Src/Message/Makefile
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Message'
Making all in Utils
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Utils'
 cd ../.. && /bin/sh ./config.status Src/Utils/Makefile depfiles
config.status: creating Src/Utils/Makefile
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Utils'
make[2]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Provider'
 cd ../.. && /bin/sh ./config.status Src/Provider/Makefile depfiles
make[2]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Provider'
if /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DPACKAGE_NAME=\"FDOSDF\" -DPACKAGE_TARNAME=\"fdosdf\" -DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"FDOSDF\ 3.3.0\" -DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdosdf\" -DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1  -I. -I. -I../../Inc -I/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Inc -I/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Src/Nls -I/usr/include -I../Message/Inc -I../Utils -I/usr/src/mapguide/FDO/OpenSource_FDO/Utilities/Common/Inc -I/usr/src/mapguide/FDO/OpenSource_FDO/Utilities/SQLiteInterface -I/usr/src/mapguide/FDO/OpenSource_FDO/Utilities/ExpressionEngine/Inc    -O2 -DSQLITE -D_FILE_OFFSET_BITS=64  -MT SchemaDb.lo -MD -MP -MF ".deps/SchemaDb.Tpo" -c -o SchemaDb.lo SchemaDb.cpp; \
then mv -f ".deps/SchemaDb.Tpo" ".deps/SchemaDb.Plo"; else rm -f ".deps/SchemaDb.Tpo"; exit 1; fi
 g++ -DPACKAGE_NAME=\"FDOSDF\" -DPACKAGE_TARNAME=\"fdosdf\" -DPACKAGE_VERSION=\"3.3.0\" "-DPACKAGE_STRING=\"FDOSDF 3.3.0\"" -DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdosdf\" -DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I. -I../../Inc -I/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Inc -I/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Src/Nls -I/usr/include -I../Message/Inc -I../Utils -I/usr/src/mapguide/FDO/OpenSource_FDO/Utilities/Common/Inc -I/usr/src/mapguide/FDO/OpenSource_FDO/Utilities/SQLiteInterface -I/usr/src/mapguide/FDO/OpenSource_FDO/Utilities/ExpressionEngine/Inc -O2 -DSQLITE -D_FILE_OFFSET_BITS=64 -MT SchemaDb.lo -MD -MP -MF .deps/SchemaDb.Tpo -c SchemaDb.cpp  -fPIC -DPIC -o .libs/SchemaDb.o
SdfExtHashMap.h: In member function ‘size_t __gnu_cxx::hash<void*>::operator()(void* const&) const’:
SdfExtHashMap.h:34: error: cast from ‘void*’ to ‘int’ loses precision
make[2]: *** [SchemaDb.lo] Error 1
Making install in Utils
make[3]: Entering directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Utils'
make[3]: Leaving directory `/usr/src/mapguide/FDO/OpenSource_FDO/Providers/SDF/Src/Utils'
linux-n5su:/usr/src/mapguide/FDO/OpenSource_FDO # ./build_linux.sh >erorile
ClientServices/prefix.cpp: In function ‘char* br_locate(void*)’:
ClientServices/prefix.cpp:132: error: cast from ‘void*’ to ‘unsigned int’ loses precision
make[4]: *** [prefix.lo] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[3]: *** [install-recursive] Error 1
make[2]: *** [install-recursive] Error 1
make[3]: *** No rule to make target `/usr/src/mapguide/FDO/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la', needed by `libExpressionEngine.la'.  Stop.
Can you give me some directions?
Thanks, Dorin
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Saturday, May 24, 2008 2:19:33 PM
Subject: RE: [mapguide-users] Problems of building fdo-3.3.0
/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la does not exist. What error did you get building
/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Fdo/Unmanaged?
Sent: Saturday, May 24, 2008 1:48 AM
Subject: [mapguide-users] Problems of building fdo-3.3.0
Hi all,
I tried to build FDO 3.3.0 in order to instal MGOS 2.0.1. on Linux SUSE 10
 I got th following error:
make[2]: *** No rule to make target `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la', needed by `UnitTest'.  Stop.
make[2]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
make[1]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src'
make[1]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src'
make[2]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Message'
make[2]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Message'
make[2]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[3]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[3]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[2]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Overrides'
make[2]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[3]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[3]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[2]: Leaving directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/Provider'
make[2]: Entering directory `/usr/src/mapguide/Fdo-3.3.0/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
Any suggestion?
Thanks,
Dorin
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080527/0182d172/attachment.html
