[mapguide-users] Erreur message ' Invalid repository type'
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Nov 6 13:27:59 EST 2008
Somewhere you are passing a string that should start with "Library://"
but does not.
Perhaps you are loading the weblayout, but passing the string like:
?weblayout=MyLayout.WebLayout
when it should be
?weblayout=Library://folder/MyLayout.WebLayout
What url does the page have that emits the error message?
Regards, Kenneth Skovhede, GEOGRAF A/S
Francis MILHAU skrev:
> Hi,
> When i try to load my application developped with mapguide studio ,
> withe Internet explorer i have this message :
> /*Invalid repository type.
> Invalid repository type. Exception occurred in method
> MgResourceIdentifier.CheckType at line 716 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\platformbase\Services/ResourceIdentifier.cpp*/
> Have you an idea ?
> thanks
> Francis
> Configuration : Client/Server
> PC under Windows 2003 Server , SP2
> IIS 7
> Mapguide Server OpenSource 2.0.1
> Geomap Server 5.6
> Autodesk Mapguide Studio 2.0
> My test : http://localhost/ggWeb2009/ggMain.aspx?version=5&target=AJAX
> <http://localhost/ggWeb2009/ggMain.aspx?version=5&target=AJAX>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081106/d3cfec80/attachment.html
