[mapguide-users] Importing map on MapGuide
Carmelo Saffioti csaffi at libero.it
Tue Nov 11 10:31:26 EST 2008
< What happens if you preview the FeatureSource ?
The Layer preview shows me my map successfully
< On the map you must enter the extent of the data, is the entered data correct?
I don't know. To set it up I clicked on button "Set view to current layers extent". How can I do?
< Is the layer visible at the current scale?
How can I know that? The Layer previews, as I said, shows me my map successfully
< Is the layer visible in the map?
The Map preview shows me a blank map. On the left I have got a panel named Layers on which I can see the name of my layer, with a checkbox near it.
  ----- Original Message -----
  To: MapGuide Users Mail List
  Sent: Tuesday, November 11, 2008 12:24 PM
  Subject: Re: [mapguide-users] Importing map on MapGuide
  Yes, that sounds correct.
  Does the server log reveal any information?
Regards, Kenneth Skovhede, GEOGRAF A/S
  Carmelo Saffioti skrev:
    Some people told me to use the SDF format... I tried, using MapGuide Maestro, to import the exported SDF file. The connection test gives me: "Provider reported no errors". After that, I used the imported file to create a new Layer. Then, I created a Map, setting up Resource on Layer properties equal to the created layer. Finally, I created a Layout, setting up Map resource equal to the created map.
    Is it correct?
    The browser displays a blank map... I hope you can help me
    Cheers
    Carmelo
      Sent: Tuesday, November 11, 2008 10:25 AM
      If you use SHP, it should be straightforward.
      The Maestro user guide is incomplete, but should get you started:
      http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
      I would recommend installing the Sheboygan sample to see how that works.
      http://mapguide.osgeo.org/download/releases/2.0.x-samples
        Hi everybody,
        I've got a DWG planimetry file from which I'd like create a digital map, managed by the MapGuide map server.
        I've converted the DWG file into different formats (dwf, dxf, sdf, shp), for importing it in the simplier way.
        How can I do to import and display it on MapGuide? Which steps should I follow?
        I tried with MapGuide Maestro, but the application I created seems to do not work properly, because the browser stays on loading...
        Cheers
        Carmelo
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081111/cc74a172/attachment.html
