[mapguide-users] Maps not visible in MgOS 2.0.2
Kimmo Kotajärvi Kimmo.Kotajarvi at vianova.fi
Thu Nov 13 04:22:03 EST 2008
I might be having the same problem, using MGE2009 + MGOS2.0.2 on IIS here. I can't see Sheboygan's map, but all the layers are listed correctly. How did you solve the problem?
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MacNair
Sent: 11. marraskuuta 2008 17:20
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Maps not visible in MgOS 2.0.2
Yes! Sheboyagan worked followed by my Maps too. Permissions to a few virtual
directories were not set correctly.
Thanks Andy!
Andy Morsell wrote:
> Do the sample maps from the Sheboygan sample dataset work?  If not, then
> it
> looks like an IIS and MGOS installation and configuration issue.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> Sent: Monday, November 10, 2008 9:50 PM
> Subject: [mapguide-users] Maps not visible in MgOS 2.0.2
> Am unable to view maps (authored in Mge2009 Studio) via our Mapguide
> application with Maguide Open source 2.0.2 Server. The viewer gives a
> blank.
> However, we are able to view the maps through our application with Mge
> 2009
> server though.
> These maps have the following data authored...
> 1. Themed layers
> 2. Feature joins between SDF and SQL server table.
> I was able to view these maps previously (authored in Mge2008 Studio) with
> using Mapguide open source 1.2. I recently installed Mapguide open source
> 2.0.2 to try the maps authored in Mge2009. The open sources Windows
> installer didn't create the virtual directory at the end of the
> installation. I did it manually and configured the application in IIS. The
> installation was done on Win2003 SP2.
> Suggestions are welcome. Issues with application configuratin in IIS which
> I
> did manually?
> Thanks and Regards!
> http://n2.nabble.com/Maps-not-visible-in-MgOS-2.0.2-tp1483925p1483925.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Maps-not-visible-in-MgOS-2.0.2-tp20433988p20441704.html
