[mapguide-users] Problem connecting to ArcSDE9.2
Steve G steve.golden at morganhill.ca.gov
Tue Nov 18 19:21:21 EST 2008
I am currently using OSGeo.ArcSDE.3.3 FDO and trying to connect to an
ArcSDE9.2 database using Maestro.  When I try to set up a new data
connection and use the "Test Connection" button, I get the following error
message:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
FDO Provider entry point function 'CreateConnection' returned NULL.
Exception occurred in method MgFdoConnectionManager.Open at line 262 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
I have checked the dlls and they all seem to be in the correct folder
(Server\Bin\FDO).  Does anyone have any suggestions of what the problem and
solution might be?
Thanks,
Steve
View this message in context: http://www.nabble.com/Problem-connecting-to-ArcSDE9.2-tp20571485p20571485.html
