[mapguide-users] Scribble2
Dave Wilson dave.wilson at autodesk.com
Tue Nov 25 13:32:22 EST 2008
I had tried the original scribble on MGE 2009 and had problems with it. After 1 or 2 operations things didn't work. I don't recall specifics unfortunately at the moment, but I don't believe I could execute most of the features when it came to red lining. This was against the AJAX Viewer. I'm just curious if anyone else had similar issues?
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Tuesday, November 25, 2008 11:11 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Scribble2
Does the rest of the Scribble application work for you?  Are you only having problems with the PDF portion?  Did you copy the MGOS dll files into the Scribble bin directory?
Andy
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pedro Venâncio
Sent: Tuesday, November 25, 2008 7:33 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Scribble2
Hello!
I am trying to install the package of Scribble (from Andy), but it gives me the error of the image attached. Then, when I click "PDF Document", show me this message:
Server Error in '/mapguide/Scribble' Application.
Failed to retrieve message for "MgConfigurationException".
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: OSGeo.MapGuide.MgConfigurationException: Failed to retrieve message for "MgConfigurationException".
Source Error:
Line 843:        this._session = session;
Line 844:        this._site = new MgSiteConnection();
      Line 845:        this._site.Open(new MgUserInformation(session));
      Line 846:        this._Session_StringBuilder = new StringBuilder();
Line 847:        this._Session_StringBuilder.Append("Session:");
Source File: c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs    Line: 845
Stack Trace:
[MgConfigurationException: Failed to retrieve message for "MgConfigurationException".]
   OSGeo.MapGuide.SWIGExceptionHelper.ThrowCustomException(String className, IntPtr cptr) +176
   OSGeo.MapGuide.MapGuideApiPINVOKE.MgSiteConnection_Open(IntPtr jarg1, IntPtr jarg2) +0
   OSGeo.MapGuide.MgSiteConnection.Open(MgUserInformation userInformation) +20
   ScribbleMethodsMgr.SetUp(String session, String mapname) in c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs:845
   ScribbleMethodsMgr.MaterializeMapPDFPage(String session, String mapname, Int32 width, Int32 height, String imageflavor) in c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs:603
   scribblepdfdoc.ProcessRequest(HttpContext context) in c:\Programas\MapGuideOpenSource2.0\Scribble\scribblepdfdoc.ashx:11
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +154
 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
I followed all the steps listed for the use of the package, but I am using the MGOS 2.0.2 with php on IIS 5.1. This may be the problem?
Thank you very much!
Yours sincerely,
Pedro
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081125/9b5c9900/attachment.html
