[mapguide-users] How to pass parameter using invoke url?
Andy Morsell amorsell at spatialgis.com
Fri Nov 28 12:23:36 EST 2008
Since you must have PHP installed with any MGOS installation, there is
nothing wrong with mixing .NET and PHP.  If you do want to go the .NET
route, it is easy to manually translate the PHP since the API is identical
between languages.  If you do end up doing that, please consider
contributing it back to the group.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of jamesdudden
Sent: Friday, November 28, 2008 1:20 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] How to pass parameter using invoke url?
Andy Morsell wrote:
> This page should help clarify that for you:
> http://www.calcad.com/MGOS/PassData.html
This is almost what i need except that i am working in the .NET environment.
Does anybody have this code in asp?
Regards
James
Straightforward solutions to take care of your business
http://www.software-matters.co.uk Software Matters
View this message in context:
http://www.nabble.com/How-to-pass-parameter-using-invoke-url--tp20722492p207
31155.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
