[mapguide-users] MGOS2.0.2 bundled installation won't support php on IIS6
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Oct 1 11:54:44 EDT 2008
Ok, I'm pretty sure you don't want to change the IP address.
You should never expose the MapGuide service directly to the internet,
because that has severe security implications.
You should only expose the WebServer to the internet, because it is
built to resist attacks.
So, first step is to change all those back to their defaults, and
everything should work just fine.
Regards, Kenneth Skovhede, GEOGRAF A/S
JeffJensen skrev:
> Hello Kenneth,
> Thanks for the reply.
> I'm unable to login to site administrator once I've changed the IP address
> from localhost.
> I used  http://trac.osgeo.org/mapguide/ticket/659 ticket #659  because I
> thought this is the procedure to change the IP address of the MapGuide
> Server? On the install of MGOS I used the default of 127.0.0.1 (localhost)
> and everything works. I then wanted to change it to my WAN IP address
> (66.116.107.3) so I edited the following text files:
> 1.  webconfig.ini, under SiteConnectionProperties, change IpAddress to the
> WAN IP Address (66.116.107.3)
> 2. serverconfig.ini, under SiteConnectionProperties, change IpAddress to the
> 3. serverconfig.ini, under GeneralProperties, change MachineIp to the WAN IP
> I then restart the MapGuide Server service and even restarted the server,
> but no luck. Still getting the
> "Fatal error encountered! Please login again." error message. The message
> occurs both locally (http://localhost:8008/mapguide/mapadmin/login.php) and
> remotely (http://hostmapguide.com:8008/mapguide/mapadmin/login.php)
> I'm kinda of at a lost what to do and think I might have to watch some past
> episodes of MacGyver on youtube.com to figure it out :-)
> Thanks for all the help,
> Jeff Jensen
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> The ticket #659 relates to people trying to write an application on one
>> machine that communicates with MapGuide on another machine (on a LAN).
>> You should not follow those directions, unless you are trying to achieve
>> that.
>> As for the WAN, you just need to have your router (or ISP) redirect
>> request for port 80 (or 8008) to your machine.
>> On most routers, it is called NAT (network address translation), but
>> some call it "Virtual Servers".
>> Once done, your webserver should be visible from the WAN as well, and
>> thus MapGuide is visible too.
>> JeffJensen skrev:
>>> Hello,
>>> Following the suggestion from Andy Morsell, I uninstalled and installed
>>> the
>>> MapGuide Web Extensions for MGOS 2.0.2 using the Apache Webserver and
>>> PHP.
>>> Success! I can now login to Site Administrator.
>>> Only thing I did different on the install was to use the default
>>> localhost
>>> IP address (127.0.0.1). So now I'm trying to find where I change it to my
>>> WAN IP address for the MapGuide Server.
>>> Thanks for the help,
>>> Jeff Jensen
>>> JeffJensen wrote:
>>>> Hello,
>>>> I'm unable to connect to the Site Administrator when using a new
>>>> installed
>>>> MapGuide Open Source 2.0.2. I'm getting the "Cannot establish
>>>> connection."
>>>> error message.
>>>> I followed the suggestions from Crispin and Jason (see my notes at
>>>> http://faculty.unlv.edu/jensen/html/MapGuide/)
>>>> Any other ideas?
>>>> Jeff Jensen
>>>> Ed Jobe wrote:
>>>>> That was my next move... I've only just started with 2.0.1 and sample
>>>>> data. I was thinking I would just just clean everything up
>>>>> and reinstall 2.0.2 again.
>>>>> Ed Jobe
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081001/170a2653/attachment.html
