[mapguide-users] MGOS2.0.2 bundled installation won't support php on IIS6
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Oct 1 11:58:25 EDT 2008
What do you mean exactly with "change the ip adress of MapGuide Server" ?
I have no problem accessing your server through either DNS name or IP.
Regards, Kenneth Skovhede, GEOGRAF A/S
JeffJensen skrev:
> Hello Kenneth,
> I forgot to mention, when I change the IP address in the serverconfig.ini
> and webconfig.ini files back to 127.0.0.1 and restart the MapGuide Server
> service I'm able to login to Site Administrator. So, it appears my problem
> is how to change the ip address of MapGuide Server.
> Thanks again,
> Jeff Jensen
> JeffJensen wrote:
>> Hello Kenneth,
>> Thanks for the reply.
>> I'm unable to login to site administrator once I've changed the IP address
>> from localhost.
>> I used  http://trac.osgeo.org/mapguide/ticket/659 ticket #659  because I
>> thought this is the procedure to change the IP address of the MapGuide
>> Server? On the install of MGOS I used the default of 127.0.0.1 (localhost)
>> and everything works. I then wanted to change it to my WAN IP address
>> (66.116.107.3) so I edited the following text files:
>> 1.  webconfig.ini, under SiteConnectionProperties, change IpAddress to the
>> WAN IP Address (66.116.107.3)
>> 2. serverconfig.ini, under SiteConnectionProperties, change IpAddress to
>> the WAN IP Address (66.116.107.3)
>> 3. serverconfig.ini, under GeneralProperties, change MachineIp to the WAN
>> I then restart the MapGuide Server service and even restarted the server,
>> but no luck. Still getting the
>> "Fatal error encountered! Please login again." error message. The message
>> occurs both locally (http://localhost:8008/mapguide/mapadmin/login.php)
>> and remotely (http://hostmapguide.com:8008/mapguide/mapadmin/login.php)
>> I'm kinda of at a lost what to do and think I might have to watch some
>> past episodes of MacGyver on youtube.com to figure it out :-)
>> Thanks for all the help,
>> Jeff Jensen
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> The ticket #659 relates to people trying to write an application on one
>>> machine that communicates with MapGuide on another machine (on a LAN).
>>> You should not follow those directions, unless you are trying to achieve
>>> that.
>>> As for the WAN, you just need to have your router (or ISP) redirect
>>> request for port 80 (or 8008) to your machine.
>>> On most routers, it is called NAT (network address translation), but
>>> some call it "Virtual Servers".
>>> Once done, your webserver should be visible from the WAN as well, and
>>> thus MapGuide is visible too.
>>> JeffJensen skrev:
>>>> Hello,
>>>> Following the suggestion from Andy Morsell, I uninstalled and installed
>>>> the
>>>> MapGuide Web Extensions for MGOS 2.0.2 using the Apache Webserver and
>>>> PHP.
>>>> Success! I can now login to Site Administrator.
>>>> Only thing I did different on the install was to use the default
>>>> localhost
>>>> IP address (127.0.0.1). So now I'm trying to find where I change it to
>>>> my
>>>> WAN IP address for the MapGuide Server.
>>>> Thanks for the help,
>>>> Jeff Jensen
>>>> JeffJensen wrote:
>>>>> Hello,
>>>>> I'm unable to connect to the Site Administrator when using a new
>>>>> installed
>>>>> MapGuide Open Source 2.0.2. I'm getting the "Cannot establish
>>>>> connection."
>>>>> error message.
>>>>> I followed the suggestions from Crispin and Jason (see my notes at
>>>>> http://faculty.unlv.edu/jensen/html/MapGuide/)
>>>>> Any other ideas?
>>>>> Jeff Jensen
>>>>> Ed Jobe wrote:
>>>>>> That was my next move... I've only just started with 2.0.1 and sample
>>>>>> data. I was thinking I would just just clean everything up
>>>>>> and reinstall 2.0.2 again.
>>>>>> Ed Jobe
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081001/922e405c/attachment.html
