[mapguide-users] MGOS2.0.2 bundled installation won'tsupportphpon IIS6
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Oct 1 12:02:52 EDT 2008
Apache has its own strengths, and if you are not using IIS features
(integrated authentication, .Net, etc) in MapGuide,
I can see why you would want to use Apache.
If you have a .Net application on the same server, you may want IIS too.
The install documents assume that you choose Apache and PHP.
Anythin else means you're on your own.
If you get a list of changes, please do post them as a ticket in Trac.
Regards, Kenneth Skovhede, GEOGRAF A/S
ed57gmc-bus at yahoo.com skrev:
> Thanks Kenneth,
> I didn't realise you could install Apache /and/ IIS. What would be the
> reason for doing so? I guess, then, that when the install guide was
> written, it was with Apache in mind (i.e. specifying 8008)? I found
> other discrepancies and things that need updating in the install
> guide. I was thinking of making some corrections and submitting it.
> Ed Jobe
> ----- Original Message ----
> From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, October 1, 2008 12:02:24 AM
> Subject: Re: [mapguide-users] MGOS2.0.2 bundled installation
> If you install Apache, it will use port 8008, because you may have
> other stuff (IIS?) using port 80.
> Whenever you do something with the Site Admin, it communicates with
> the MapGuide service over a port on the loopback interface.
> This port is NOT 8008, and should not be either.
> Whenever your application communicates with the MapGuide service, it
> uses another port on the loopback interface.
> (It may redirect to another machine, but usually it is the same
> machine, and thus a loopback).
>> Are the port numbers the same in the web config file and the server
>> config file?
>> Yes, there are 3 ports config'd and they were the same in both files.
>> They weren't 8008 though. I didn't get prompted to specify
>> them during install like I did with 2.0.1.
>> Speaking of ports, the doc's mention localhost:8008. If I use that,
>> it can't find login.php. If I just use localhost, it can. Could
>> someone explain why?
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081001/32609e6a/attachment.html
