[mapguide-users] MGOS2.0.2 bundled installation won'tsupportphpon IIS6
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Oct 1 12:40:32 EDT 2008
Yes, you could serve different pages with Apache and IIS from the same
machine.
Currently there is no integration between MapGuide and AD/LDAP, so you
must create users manually in MapGuide.
I will warn you that the MapGuide security model is bad, if not broken
(My personal opinion).
There are a number of ways to log on for users, so they are not prompted.
You should be able to find a few threads on the subject on nabble.
Regards, Kenneth Skovhede, GEOGRAF A/S
ed57gmc-bus at yahoo.com skrev:
> Its getting a little clearer. e.g. you could have one folder on the hd
> managed by IIS and another folder managed by Apache, correct?
> Now that you mentioned authentication, I plan to do that, but can't
> find any documentation on mg's groups and users. I read some blurb
> somewhere that everyone is requred to log in but I haven't experienced
> that requirement using Sheboygan. I should start another thread on
> that when I get to that point.
> I'll definitely try to post my finding on trac, if I can stay
> on track.  ;-)
> Ed Jobe
> ----- Original Message ----
> From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, October 1, 2008 9:02:52 AM
> Subject: Re: [mapguide-users] MGOS2.0.2 bundled installation
> Apache has its own strengths, and if you are not using IIS features
> (integrated authentication, .Net, etc) in MapGuide,
> I can see why you would want to use Apache.
> If you have a .Net application on the same server, you may want IIS too.
> The install documents assume that you choose Apache and PHP.
> Anythin else means you're on your own.
> If you get a list of changes, please do post them as a ticket in Trac.
>> Thanks Kenneth,
>> I didn't realise you could install Apache /and/ IIS. What would be
>> the reason for doing so? I guess, then, that when the install guide
>> was written, it was with Apache in mind (i.e. specifying 8008)? I
>> found other discrepancies and things that need updating in the
>> install guide. I was thinking of making some corrections and
>> submitting it.
>> Ed Jobe
>> Sent: Wednesday, October 1, 2008 12:02:24 AM
>> If you install Apache, it will use port 8008, because you may have
>> other stuff (IIS?) using port 80.
>> Whenever you do something with the Site Admin, it communicates with
>> the MapGuide service over a port on the loopback interface.
>> This port is NOT 8008, and should not be either.
>> Whenever your application communicates with the MapGuide service, it
>> uses another port on the loopback interface.
>> (It may redirect to another machine, but usually it is the same
>> machine, and thus a loopback).
>>> Are the port numbers the same in the web config file and the server
>>> config file?
>>> Yes, there are 3 ports config'd and they were the same in both
>>> files. They weren't 8008 though. I didn't get prompted to specify
>>> them during install like I did with 2.0.1.
>>> Speaking of ports, the doc's mention localhost:8008. If I use that,
>>> it can't find login.php. If I just use localhost, it can. Could
>>> someone explain why?
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081001/4c45ef11/attachment.html
