[mapguide-users] RE: Tiffs and MGOS 2.01
Zac Spitzer zac.spitzer at gmail.com
Thu Oct 2 01:09:05 EDT 2008
coming very soon - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
it was just committed to subversion, you should be able to compile a version
so you got rasters with GDAL working stably? cool
z
On Thu, Oct 2, 2008 at 3:06 PM, Mark Pendergraft <markp at meadgilman.com> wrote:
> I have upgraded to 2.02 and now I can see the tiff in my map.  however, I
> can only see the tiff in my map when the coordinate system is the same as
> the coordinate system in the tiff (regardless of overrides).  Any ideas?
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
> Pendergraft
> Sent: Wednesday, October 01, 2008 4:22 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] RE: Tiffs and MGOS 2.01
> I did have a coordinate system override specified at first.  It was the same
> coordinate system as my map (WAHP-NF), but when I looked at it in the layer
> preview, the scale was 1:4.65.  Seeing as the TIFF covers the entire Puget
> Sound in Washington State, I knew something was up.  So I didn't specify an
> override, and I create a new map with the same coordinate system as the
> tiff.  When I look at the tiff in the layer preview sans override, the scale
> is 1:1698729.00 (which is more like it).
> However in my map with the same coordinate system, I see nothing.
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
> Sent: Wednesday, October 01, 2008 4:12 PM
> Subject: [mapguide-users] RE: Tiffs and MGOS 2.01
> Did you specify a coordinate system override on your Data connection so that
> when you add the layer to the map it knows what CS it's in?
> Dave
> Pendergraft
> Sent: Wednesday, October 01, 2008 4:56 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Tiffs and MGOS 2.01
> I'm having trouble with TIFF's in MGOS 2.01.  I'm using Mapguide Studio 2009
> and the GDAL provider.  I can create a data resource from a directory
> containing 4 tiffs (downloaded from USGS National Map - NED Imagery).  And
> I'm able to create a layer, and view the tiff data in the layer preview.
> Everything is fine until I add it into my map.  It doesn't show up at all.
> I have even made another map with just the tiff layer, and zoomed way out.
> Nothing.  I have tried different coordinate systems, and I'm currently using
> the LL83 (which is the same as the tiff coordinate system) and I've even
> plugged in the lat/longs from the tiff's lower/upper corners into the map.
> Am I missing something here?
> Thanks.
> -Mark Pendergraft
> mapguide-users mailing list
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
