SQLite provider (was: RE: [mapguide-users] Move Default Repository Location?)
Traian Stanev traian.stanev at autodesk.com
Thu Oct 2 19:47:36 EDT 2008
Of course it allows you to create files with the API -- in the same way as other file-based providers. The converter that comes with the provider is purely FDO code and it uses the FDO API to create new files.
Someone just needs to try it with FME and log any problems that come up so I can fix them.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Thursday, October 02, 2008 5:00 PM
> To: MapGuide Users Mail List
> Subject: SQLite provider (was: RE: [mapguide-users] Move Default
> The latter, and then use the SQLite provider to connect to them.
> FME doesn't support writing out SQLite in a format that the FDO
> provider
> will read (I think), so you would probably need to write to SDF or SHP
> and then use the commandline SDF->SQLite converter tool that is
> included
> with the SQLite provider.
> You MAY also be able to drop the SQLite provider into a recent version
> of FME (the 2009 betas are using FDO 3.3) and then write out using the
> FDO Providers writer, but I'm not sure if the SQLite provider allows
> you
> to create new files through the API.
> Jason
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JeffJensen
> Subject: RE: [mapguide-users] Move Default Repository Location?
> Are you saying I can use the SQLite Provide instead of the OSGeo FDO
> Provider for SDF?
> Or are you saying, don't use SDF3 files, but load the data into SQLite
> instead?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
