[mapguide-users] How to config the WMS Data/Layer published byMapGuide and how to set the access way to it?
Jason Birch Jason.Birch at nanaimo.ca
Mon Oct 6 11:50:11 EDT 2008
I don't think that there are a lot of folks here with direct OpenLayers
experience, so you may need to provide more details.
I think that your first problem is probably due to JavaScript's
same-origin policy.  Is your OpenLayers map running on a different host
than the MapGuide server?
For the second issue, I would probably want to run a network sniffer
like Fiddler2 or the one built into FireBug to see what is being
requested from the MapGuide WMS and if there is an exception being
returned.  Also, make sure there is data in view at the scale being
displayed.
Jason
-----Original Message-----
Subject: [mapguide-users] How to config the WMS Data/Layer published
I need to access Mapguide OverLayer to Openlayers, but there are
something
wrong with it (access denied with XMLHttpRequest.open(......)).
So I moved to Add WMS Layer published by MapGuide. I tested many times,
there is always a empty image displayed.
How to config the WMS Data/Layer published by MapGuide and how to set
the
access way to it?
