[mapguide-users] StatusScale issue in scale ranges
Rodolfo Moreno rmoreno at voxiva.com
Mon Oct 6 12:13:56 EDT 2008
Hi Maskin,
I have tried the range scales that you suggest me
and the wrong behavior continues.
I realized as well that It only happen it in the edge of the scale range (at
least for my case).
for instance:
range scales:
range1: 0-15001
range2: 15002 - inifinite
the map starts in range2. next I put 15001 (inside of the range1) in status
scale and the layer disappears. however when I put 15000 or numbers less
than 15001 the layer shows up (right behavior).
I only have tested with mapguide server 2.0.1, I don't know whether this
issue has been solved in the 2.0.2 version.
Regards,
Maksim Sestic wrote:
> Hi Rodolfo,
> It's a known (?) bug, at least with MGE 2008. You better use:
> 0 - 15001
> 15002 - Infinity
> set of ranges. It seems that something's broken with "inclusive" part of
> the
> range.
> Regards,
> Maksim Sestic
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Sunday, October 05, 2008 17:23
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] StatusScale issue in scale ranges
> Hi Kenneth,
> I know the behavior of the scale ranges.
> My case is the following¨
> I have two scale ranges
> 0-15000
> 15001 - infinite
> when I start the map can see the layer according to 15001 - inifinte scale
> range, however when you do zoom in until 15000 using the status scale the
> layer disappears. When I do the same usign the slider, zoom rectangle or
> zoom in tool the layer shows up according to 0-15000 scale ranges.
> It happen with any of viewers (fusion, ajax or dwf).
> Regards,
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Can you clarify the problem a bit?
>> If you have a layer with scale ranges:
>> 0-2000 : Red dots
>> 2001-Infinite : Blue dots
>> Does it change from blue to red if you type in "2000" in the status
>> bar at the bottom?
>> Does it change if you use the slider (to the same range)?
>> Does it change if you drag a rectange (to the same range)?
>> (The change is expected behavior)
>> If you have ranges:
>> 0-2000
>> 4000-Infinite
>> The layer will be invisible in the range [2001-3999], which is correct
>> behavior.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Rodolfo Moreno skrev:
>>> Hi all,
>>> I got an issue in mapguide 2.0.1.
>>> Layers with different scale ranges become invisible when you do zoom
>>> in with the StatusScale until to achieve one of the scale ranges.
>>> It happens with any of the viewers (AJAX, DWF or FUSION), which is
>>> why I think that the problem is the mapguide server.
>>> I don't know whether this issue has been solved in the 2.0.2 version
>>> I would like to know whether someone has gotten the same problem.
>>> Regards
>>> Rodolfo Moreno
>>> CivilEng
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/StatusScale-issue-in-scale-ranges-tp1142302p1298894.htm
> l
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature
> database 3495 (20081004) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> signature
> http://www.eset.com
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/StatusScale-issue-in-scale-ranges-tp1142302p1301256.html
