[mapguide-users] ArcSDE FDO sucks !!!
shreepad Ranadive shreepadr at valuecad.com
Mon Oct 6 17:28:16 EDT 2008
thanks jason
i will create a trac for this on fdo site.
I have tested this with  couple layers with new schema created its still
slow.
let me create trac to have it looked at by developers
thanks
shreepad
JasonBirch wrote:
> You may be asking on the wrong list if you want the FDO folks to
> respond.  Though I'm sure that some of them hang out here from time to
> time, fdo-users is a better place.  Might want to use a less
> inflammatory subject line though :)
> The problem may not be with the SDE provider though; I wonder if it is
> the same problem with initial schema load as has been seen with the
> RDBMS providers.  Does performance decrease as the number of tables
> stored in the SDE increases, or is it consistently slow?
> The best way to get this fixed is to clearly describe the problem,
> preferably with test data, in a Trac ticket.  Just saying that it is
> slow is not giving the developers enough to chew on.
> Jason
> -----Original Message-----
> From: shreepad Ranadive
> Subject: Re: [mapguide-users] ArcSDE FDO sucks !!!
> I found the same issue. the new fdos are bit slow with sde 9.1 /9.2
> i think some one from FDO team should take a look at it seriously
> FDO team : please have some reply to this request
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Shreepad Ranadive
Direcotor , Application Development
ValueCAD
444 Natoma St
Sanfrancisco,CA 94103
View this message in context: http://www.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp19832086p19846802.html
